Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Like Tree1Likes
  • 1 Post By PDUB
Old 04-03-2025, 06:11 AM
Default Help identifying jaguar IRS
Id like to know the year/model Jaguar that my rear end came from. I need to know for ordering parts, brakes and possibly changing the rear center section to different gearing. Is there any source or guide for identifying these IRS rears?
Thanks!
Old 04-03-2025, 07:05 AM
ERA174's Avatar
Cobra Make, Engine: ERA 427, 482ci sideoiler
The following link is to a prior post that may be helpful.
Jaguar Diff identification.
Old 04-04-2025, 01:45 AM
Exclamation
This is a link that has some info to help:
https://www.firstcoastcobraclub.com/....php?f=1&t=198
Good luck!
mvanhorn8893 likes this.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 04-04-2025, 03:41 PM
Get under the car with a light and mirror.
You need to see the ID tags and casting stamps
found on the differential.
Metal ID tags will be attached to a carrier cover bolt.
The one pictured has the numbers 43 & 13.
43 denotes the ring gear teeth.
13 denotes teeth on pinion.
43/13 = 3.31 differential gear ratio.
46/13 = 3.54 differential gear ratio.
If you have 43/13 tag, a drain AND fill plug, there is a
strong possibility it's from a ('73-79) Series II XJ6
The year will be stamped into the casting such as
shown in the attached picture of a '74 XJ6.
Moss Motors has exploded views of the entire
Jaguar rear suspension. Click the number on the
diagram and it takes you to the corresponding part.
Here's a link to the Moss Motors XJ6 suspension diagrams to get you started.
https://mossmotors.com/jaguar-xj6-xj...48506e2e8e326f
Display Modes
