11-03-2008, 09:59 PM
Small parts needed for Jaguar rear
I am missing the small grease caps that fit into the holes on the aluminum hubs on the Jag rear setup. They're about the diameter of a nickel or so, and have a dome top with a small hole drilled in them. They cover the hole that is drilled into the aluminum hub housings. I know this isn't a great description of the parts needed but I can't think of another way to describe them. Does anyone have a pair of these laying around that they'd part with, or know where I can get them from? I usually buy Jag suspension parts from SNG Barrett but these caps don't show up in their catalog. Anyone have a pair laying around or know where I can find them new? I can't imagine that these things are very expensive but I don't want to assemble without them. Thanks!
11-03-2008, 10:23 PM
Cobra Make, Engine: Past owner ERA 146, ERA 694 in progress, 428 CJ, toploader
Here's a source
Reason: added new source
11-04-2008, 02:52 AM
Put Grease fittings in the holes
767Jockey Doug I used grease fittings in these 2 holes. I also shoot some wheel bearing grease in there. This makes it easier for the parts to come apart without the big hammer theory. Rick L.
11-04-2008, 07:22 AM
Rick,
How did you adapt the holes for grease fittings? The holes themselves are pretty big, did you install the fittings into the caps that I'm missing?
11-04-2008, 09:12 AM
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
grease fitting/cap
Doug:
What about XK-unlimited? I have grease fittings on mine. you're welcome to stop by to check it out.
Ralph
11-04-2008, 11:10 AM
Here's another possibility (see bottom of page): http://www.cwiinc.com/parts.htm
Tom
11-05-2008, 04:40 PM
Tom, These look perfect. Just this morning as I was flying out in the middle of nowhere I was actually thinking of looking into having just such a item machined up on a custom basis. Are these guys at CWI still in business? I remember trying to contact them a while back and had no response in many tries. Anyone know if they're still around? I'm out of the country right now but I guess I'll give them a try when I get back in. Great idea, Tom - thanks!
11-06-2008, 12:54 PM
az
While you were flying in the middle of nowhere was your head on a swivel while you were thinking these thoughts?
double ugly
11-06-2008, 02:07 PM
11-06-2008, 03:38 PM
fl
Cobra Make, Engine: scratch building
Grease fittings
I made mine ,aluminum 6061 , on my lathe in about 30 minutes.Should be able to find someone to knock them out for ya...Good luck. Don't forget the small vent hole next to grease fitting.
11-06-2008, 03:40 PM
Always! How are you, John?
01-08-2009, 08:00 PM
So how do they look in there Doug?
01-09-2009, 07:34 PM
Perfect - they work just fine, thanks Nick!
01-09-2009, 07:41 PM
So send me a good pic when you get a minute. I got the turkey pan today.
01-12-2009, 04:59 PM
Doug
Post a pic of the fitting......
01-13-2009, 03:14 PM
Jeff, If I could figure out posting pics I would. I emailed the pics to Nick - hey Nick, can you post them here for me for all to see? Thanks!
01-13-2009, 03:16 PM
I'm as useless at that stuff as you are. I did cut your Turkey Pan apart yesterday and made the new bottom. It's looking better than the other one...........
01-13-2009, 03:39 PM
http://xks.com/
THat's where I go for most of my jag parts.
Dan in Arizona
CCX3209
04-17-2009, 06:44 PM
04-19-2009, 06:40 AM
Nick,
Nice specialty parts! I may need a pair of those nipples.....
