Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Contemporary Classic Forums
Old 05-31-2009, 04:56 PM
streetrod1927's Avatar
Cobra Make, Engine: Contemporary Classic Motor Car; 427 S/O
Default Fuel pressure issue
Noticed that my fuel pressure keeps jumping to the 10 lb mark after driving for a while. Generally runs about 5-7 lbs. When the pressure inches up the car seem a bit sluggish on take off. Could the regulator be on its way out. I'm running a 427 FE s/o with a LeMans carb. No electric fuel pump, standard ford mechanical pump.
Old 06-01-2009, 08:20 AM
bobcowan's Avatar
I would replace the regulater fisrt. After that, I would be looking at the fuel pmp.
Old 06-01-2009, 01:18 PM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Is your gauge a liquid filled one? If so, the heat will give a false pressure reading when it gets hot.
Old 06-01-2009, 02:47 PM
Default Fuel pressue issue
No, it is not a liquid filled gauge. It is also inside the cabin. It was antifreeze coming in after the regulator, but it picks up fuel from the incoming fuel line to the carb.
