Go Back   Club Cobra > Cobra Talk Areas > Coupe Talk
February 2026
Old 10-11-2015, 04:53 PM
Cobra Make, Engine: 1968 GT350, FFR Daytona Coupe
Default tail light lens
How do they come off. I thought I saw that they just pry off.
I didnt build this rocket, but I want to add LED brake lights to it without causing damage.
The Nut
Enough is enough. Too much is just right ( C.S )
Old 10-12-2015, 02:16 AM
Bryan Wilson's Avatar
Default stop tail lights removal
Get a small screw driver and insert it behind the trim ring and lever the ring out of the rubber and the glass will come straight out. I did that to change the bulb and lost the glass and trim ring. So if you dont need the lenses or rings I would greatfully accept one cause I cant find anyone that will sell only the missing parts
VK3KDN
Old 10-12-2015, 03:28 AM
Ron61's Avatar
On my Factory Five you lift up the rubber ring around the lens and it will come out. Takes a bit of doing to be sure and not tear the rubber but it can be done.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 10-12-2015, 11:58 AM
Default lens
Thanks Guys. And I hope to hang onto mine, so there wont be any spare ones .
The Nut
Old 12-10-2015, 07:50 PM
PANAVIA's Avatar
we have found that most LED tail light replacement bulbs dont fit in the vintage lucas housings - you might want to test fit carefully to avoid damage.
Old 05-02-2016, 10:59 AM
UPDATE !! The lenses came off just as you fellas told me they would.
The LEDS did nt work out. They werent brighter
I did find my builder used a socket and bulb for 57 type bulb for the brakes. (dual filament)
Only the brighter filament was active, so I jumpered the socket so both filaments light up.
Just a little brighter.
Next is replacing the master disconnect switch. The one I have, the key is removeable. Im always concerned someone will take the key and I ll be stranded. Replacing it with a nonremoveable unit.
The Nut
