| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
1Likes
Post By mickmate
06-23-2014, 07:17 AM
Wi
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Mig weld a stainless steel o2 bung to mild steel header
Can I mig weld a stainless steel o2 bung to a mild steel header using a MIG welder using normal flux core wire?
Since I am a newbie, would it be much different that welding mild steel to mild steel? (I don't want to mess up the headers)
I have a 140 amp MIG with .35 core wire, .25 is available.
06-23-2014, 07:23 AM
NH
Use a stainless wire to weld them together and you'll be good.
06-23-2014, 07:56 AM
Wi
Ok, so I take it that I cannot use Flux core right?
If so getting the stainless steel wire (plus getting the gas/tank) would be pretty costly investment, I might be better off seeing if I can source someone to do it.
06-23-2014, 08:05 AM
va
Cobra Make, Engine: Coombe, Shelby Block 496
Hi
I would use a Tig with stainless wire, good luck.
06-23-2014, 09:57 AM
IL
Its just an ox sensor bung. Weld it with what you have. Both metals will somewhat mix with the weld. Get a small piece of stainless and weld it to some mild steel for practice and see how it reacts.
Mark
06-23-2014, 04:58 PM
NH
That was going to be my next suggestion try welding some stainless to mild with what you have. Just don't leave what you stole from the kitchen lying around after.
The other suggestion is 035 308L FCO Gasless Stainless Steel MIG Welding Wire | eBay
06-23-2014, 05:17 PM
va
If you have to buy stainless wire or have to pay some to do the job just buy a steel bung and weld away with your mig.
06-23-2014, 06:15 PM
ME
Cobra Make, Engine: ERA 427 S/C W/Holmon Moody Original Nascar build #508 Iron Block/heads (C5AE-H) Bal/Blu 427 Sideoiler; 780 Holley Dbl. Pump; 4 Speed Top Loader; AP Racing Bks; IRS; 15" Trigo pins
I would styongly suggest that you use a tig welding setup & 309 welding wire to combine the SS to the carbon!!!! 309 wire is designed for joining to two metals together. It is the only sure way to do it rite.
06-23-2014, 06:30 PM
Just weld it. You won't have any problem. We did it all the time when I worked in a muffler shop years ago.
06-23-2014, 06:57 PM
CA
I agree with using TIG. You will get a cleaner result.
06-23-2014, 09:11 PM
Ca
Use tig exclusively and get a mild steel bung? Never look back........
Rick
06-23-2014, 09:16 PM
AZ
Nick, have you used that gasless wire? What did you think?
Alba gu brąth
06-24-2014, 05:35 AM
NH
Smokey but it works well. Machine polarity has to be set for gasless wire or they don't work fer nothin.
