Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > David Kee Toploader Transmissions Inc. Speak with David.
Old 12-18-2001, 05:31 PM
Default Toploader questions
I have a HEH-CL Toploader I just recieved,
1.] How hard would it be to convert this to big in big out?
2.] Is this even possible?
3.] Out of curiousity is there major differences in the cases between the small and big input and output shaft cases?
4.] Is big in/out needed for my situation?
it will be a 1968 shortbox Pickup and behind a 410 estimated weight about 4000lbs 3800gvw+driver. The 410 will put out just under 500 ft/lbs of torque and I may play with medium sized shots of nitrous 200horse max.
5.] Will changing the intput or output shafts require changing the gears too?
Thanks for your time,
Caleb
Old 12-22-2001, 07:10 PM
To change to a big in/out you will need a 1 3/8" modular input shaft, 1 3/8" bearing retainer, 31 spline output shaft, 31 spline tailhousing. Everything else is the same. Judging by the weight and hp you are talking about, and especially the nitrous factor I would upgrade now.
Old 12-23-2001, 12:04 AM
What kind of prices am I looking at for that stuff? and also is the 31 spline tailhousing a lot more expensive for the short version? I just ordered a V-gate and ordered the install kit for the shorter tailhousing. I imagine I'd also need a 31 spline yoke too...
Old 12-23-2001, 08:10 AM
Wide ratio 1 3/8" modular input $225
1 3/8" bearing retainer $70
24" 31 spline mainshaft $225
24" 31 spline tailhousing $250 (The same shifter will work)
31 spline x 1330 yoke $68
Old 12-23-2001, 08:21 PM
Are you open tomorrow? (12-24-01) and how late if so? I'm not running the 410 yet it's still in pieces needing machined. but I'd kinda like to get the tranny in behind a 360 already in the truck so that I can get the driveline worked out with new driveshaft etc... that it'll need I'm trying to get everything done that I will need before I put the engine in so as to avoid breaking too much stuff with the more powerfrul engine
Old 12-23-2001, 09:20 PM
I hate to admit it but I will be working tomorrow 12-24. Actually I am still working right now. I should be here by 9am but I don't know how long I will be in. If you call and have to leave a message I will call you back. You can also try my cellular phone at 210-601-9101.
Old 12-24-2001, 05:25 AM
ok, well I have to work too so I'm not sure if I'll get you before you go. dont hange around if you dont want to though because the time off is great
