Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > David Kee Toploader Transmissions Inc. Speak with David.
Old 07-12-2004, 07:50 PM
Power Surge's Avatar
Question Which Parts?
David, can you answer the following questions...
Which toploader bellhousings from the ID chart on your site can be used with an FE motor in a Cobra? It looks to me that the "correct" Cobra bellhousing is the C5AA-A? Is this right? And what other ones will work?
For the trans, it looks like the HEH-BY is the proper Cobra toploader. Will any FE toploader work as long as it's a close ratio, 28 spline?
Is it true that a Tremec TKO will bolt up to a toploader bellhousing? I was told this to be true, but had never heard it before.
I have a 4000 series Shelby on order, and am trying to figure out what trans I want to run. I want the toploader for correctness, but lots of toploader guys who've switched to 5 speeds say it's the way to go. I just don't like the look of the Lakewood bellhousing, but if I can use a TKO with an OEM toploader bell, I think that's what I'd do. Any input would be appreciated. Thanks!
Sal
Sal Mennella
