Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > David Kee Toploader Transmissions Inc. Speak with David.
Old 02-20-2008, 06:39 PM
Cobra Make, Engine: RCM, 5.0L EFI Windsor
Default Top Loader Drive Gear
I was just wondering if anyone could tell me what drive gear I should have in my toploader. It is a HEH-CG code C/R 31 spline box with the large input shaft (originally out of a 66 Galaxie 428 I believe). My speedo input is on the left side of the box (i.e. on the drivers side if it were still in the original car). I can't get enough access to see it myself and would like to avoid having to remove the box just to have a look. Thanks in advance.
George H.
Old 02-20-2008, 06:59 PM
Cobra Make, Engine: EM Replica, 427 s/o, Vette suspension
It looks like you have or will need either the yellow 7 tooth or the brown 8 tooth depending on your diff ratio --- for more info see
Speedometer Gears
*** OF GREAT WORTH *** And JESUS asked again, “The Kingdom of GOD, how shall we think about it, and to what can it be compared? Is it not like a Dark blue 427 Cobra, which a man found parked on his street one day? He hurried off and sold all that he had; the ’57 Thunderbird, the ’63 Stingray, the XKE, and bought the dark blue 427 Cobra.” The disciples frowned and scraped their feet; JESUS grinned and popped the clutch. --- Harris Wolfe
Old 11-02-2008, 02:59 AM
As mentioned above, my speedometer input is on the left side of the box. I'm having clearance issues trying to get the late model mustang driven gear/speedo sensor in the box and be able to run the cable to the speedo. I was wondering whether there exists a right angle speedo driven gear adapter that fits in to the gearbox so that I will have sufficient clearance for the speedo cable? Thanks again for your help.
George H.
