Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > David Kee Toploader Transmissions Inc. Speak with David.
Old 03-28-2009, 07:28 AM
convincor's Avatar
Cobra Make, Engine: FFR 390 toploader IRS
Default Changing gear oil
My toploader doesn't have a drain plug. Is there room to drill/tap the boss in the case with the trans assembled.
Would removing the lower tail shaft bolt work as a drain?
FFR MarkIII,FE,toploader,IRS,3.27,Vintage pin's SOLD!
68 F100 Custom Cab 418 cube FE/auto
99 SuperDuty Tuner/chipped/4" Banks TOTALED!!
02 Super Duty 7.3L
Old 03-28-2009, 11:41 AM
Jeez, that's a lot of work. I would just suck it out via the fill hole. Look, here's how I do a real fast oil change before I put the ERA away for the winter. That's how I would do your transmission oil as well if it doesn't have a drain plug. I sure wouldn't yank it and drill it (wouldn't pull anything else out of it either).
Old 03-28-2009, 04:15 PM
You're sure it doesn't have a drain plug?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 03-28-2009, 04:17 PM
C'mon Brent, how could you miss a drain plug?
Rick Parker's Avatar
Look on the other side???
Rick
Old 03-28-2009, 04:27 PM
You ever seen a Toploader without a drain plug?
Old 03-28-2009, 04:37 PM
Uhhh, no.......... OK, I'll shut up until he looks on the other side.
Old 03-28-2009, 05:17 PM
convincor's Avatar
Wow, I reall didn't think I'd have to show pictures of where the drain plug would or would not be.
Do you drain your oil from the side of your oil pan? or the bottom?
"with drain plug"
"with out drain plug"
02 Super Duty 7.3L
Old 03-28-2009, 05:32 PM
Default Well, I'm Satisfied...
... Brent, say you're sorry.
Old 03-28-2009, 05:40 PM
Wow, that's a first.
Yes, I'm sorry.
Since changing gear oil isn't a 3000 mile interval thing, I'd just stick a little vacuum pump in the fill hole and suck it all out. Pulling a trans to drill and tap a hole would be a big undertaking and as anal as I am, I'd be worried sick about leaving shavings in the case.
It's been awhile since I've built a Toploader, but I don't think removing a tailhousing bolt will let it drain, but you could try.
Old 03-29-2009, 06:55 AM
Cobra Make, Engine: jbl
that's one of them there lube-for-life transmissions!
Old 03-29-2009, 07:23 AM
Tom Cimino's Avatar
Cobra Make, Engine: Everett-Morrison 427SC 302 smallblock. 431 stroker in the works, tremec 3550
I remember talking with Dan Williams years ago and he said that when you rebuild your toploader, you should drill the case for a drain plug and change the oil annually. I've had a few toploaders and have never seen one with a drain plug. The bottom bolt in the tailshaft will allow oil to drain. That's where my toploader leaked.
