January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 03-04-2010, 09:50 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
Default Heater for FIA
I'm looking into heaters for my FIA. I found some at www.vintageair.com, but I'm wondering if they will fit.
Here are my options:
Vintage Air Gen II 506101:
10.25" tall, 10" wide and 6" deep
This unit is attrative in that it has a servo unit to control coolant flow, temp control, and damper/footwell controls.
Sells for $229
Vintage Air Compact Series 50515VUH
9.5" tall, 10.5" wide and 5.25" deep
Upgradable to use the servo coolant flow control, but just a footbox heater
ERA Heater
Dimensions? Do I have to do any retrofitting other than drilling the firewall for the heater hoses? How much if I'm doing the installation?
DD
Dangerous Doug
"You're kidding, right?"
Old 03-05-2010, 05:08 AM
mickmate's Avatar
Doug do you have the cowl brace tubes? I just went behind that with a very similar unit.
mickmate
http://www.actoncustom.com/
Old 03-05-2010, 06:08 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
ERA has a heater option. Why reinvent the wheel? A non standard (ie; non-ERA) modification depreciates the car.
Jim
Old 03-05-2010, 06:18 AM
tboneheller's Avatar
Cobra Make, Engine: E.R.A. #505
Jim
More than no heater at all?
Old 03-05-2010, 06:25 AM
You should do some serious measuring. At a minimum, you're probably going to have to modify the water inlets.
Here is our current unit. It is mounted under where the wiring harness goes through the firewall. If yours does not, you'll have to shift it toward the gauges. Not much room to go there at all.
Old 03-05-2010, 07:52 AM
Five years ago ERA was using the Maradyne 5000 (which is what is in my car, a 427, not a FIA). http://www.maradyne.com/maradyne_mob...ters/5000.html
Old 03-05-2010, 08:38 AM
Cobra Make, Engine: 2008 Shelby GT500
Heaters? Heaters? We don't need no stinking heaters. I thought that is what the headers were for. My ERA FIA (#2047) didn't have a heater. Once you got going, the radiated heat from the headers made the car nice and warm on a winters morning.
FIA Mike
Old 03-05-2010, 09:04 AM
FIA Mike
DD,
X2 what Mike said. I had a heater many moons ago and removed it. I wanted a car that was as raw-boned as the S/C's were. Not a cruiser. Off came the visors, windwings, nerf bars and I never looked back. Passengers either accept that or don't go.
You live in CA-I live in the usually frozen east. Wear warmer clothes if you want to drive in 50 degree weather-avoid the expense and effort of something that doesn't add power.
But the real reason I'd like to dissuade you is the amount of work (much of it 'dirty' like hole-sawing the firewall) you'll do to an already nice car. If your car has no top the heater will be of small value-not worth the effort IMO.
I know you may have a different purpose for the car than I so if you MUST have a heater, buy the ERA part-saves a ton of headaches. Been buying ERA parts as upgrades for two decades and their parts always make every job better.
Chas.
Old 03-05-2010, 08:57 AM
My FIA is currently in the paint shop, so I'll have to mock something up when I get it back. There are a number of features I like on the vintage air Gen II heater that you don't get with the ERA unit. I like the idea of not having to pop the hood and turn a valve on when I want to turn the heater on or off.
Alternatively, no heater. However, it'd be nice to have a defroster for those cool CA coastal evenings.
DD
Dangerous Doug
Old 03-05-2010, 11:29 AM
Alright, now you guys have me feeling like a yssup* for even THINKING of adding a heater.
Bomber jacket, ski cap, driving gloves. Let the cold be damned, I'm going for a drive!
DD
* spell it backwards.
Dangerous Doug
Old 03-05-2010, 11:50 AM
Got the Bug's Avatar
DD
The SPF comes with a heater (so it wasn't a choice), but I've found it to be invaluable a number of times when the inside of my windshield instantly fogged up on Hwy 17. I guess you could just have a rag handy to wipe the inside of the windshield while you're driving.
Doug
Old 03-05-2010, 02:08 PM
tkb289's Avatar
DD
Doug,
Got the Bug Doug, has a point, the heater could come in handy keeping the windscreen from fogging up. Or, put rainX on both sides of the glass and keep a cloth close at hand.
If you do wind up going for the ERA heater (which is known to fit) and don't want the hand valve operation for controlling the water flow, a cable operated water valve might be the ticket. That's what is on my TR6 and I might see if one will work on my car, once I get it ... as I went for the yssup heater option
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
Old 03-05-2010, 02:35 PM
Originally Posted by tkb289 View Post
Doug,
...a cable operated water valve might be the ticket.
On an FIA RACE CAR replica, that will look as nifty as Pat's 2 roll hoops with rubber fire hose zipped to them---two black hoses and a spring steel-wrapped cable jutting out of the firewall and draped across the engine to a plumbing fixture.
Perfect for a quaint, antiquated TR English roadster. Original FIA cars must be spinning in their graves...
Chas.
Old 03-05-2010, 02:52 PM
They are not zip-tied; I use cheap, black electrical tape... thank you very much. And the point on defogging has merit; there are some state inspections that specifically require that in order to get legal.
Old 03-05-2010, 02:57 PM
RodKnock's Avatar
+1
FIA? Heaters? What's next cupholders, stereos, power door locks, power steering, power windows, A/C? Come on. What's up dat?
A bunch of fancy pants.
Old 03-05-2010, 01:39 PM
DD
YOU DA MAN! Now careful of the oil temps...
Chas.
Old 03-05-2010, 12:45 PM
Gatorac's Avatar
Cobra Make, Engine: BDR 930, 427 Windsor T56
I just ordered this one for my BDR. It's the smallest I could find.
http://www.southernrods.com/categori...oduct-867.html
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
Old 03-05-2010, 07:24 PM
tkb289's Avatar
Sorry guys … did not intend to rile up the natives!
I agree … if your goal is an authentic looking Racing 289 FIA, then from the front brake scoops to the bungie cord on the boot, leave it exactly as they were raced … right down to the Viking blue paint, Weber carbs and FIA wheels.
Was only making a suggestion ...
- Tim
Build Log:
Old 03-09-2010, 01:27 AM
PANAVIA's Avatar
Heater = Wife rides in cobra, using cobra in /on trips where normally a veto would be encountered. --
plus that defrosty thingy is useful.
Old 03-09-2010, 04:46 PM
Cobra Make, Engine: ERA #766, FE V8, Toploader
The ERA heater fits well. The shutoff valve at the engine = less to go wrong. Driving on 30 and 40 degree days should be much more comfortable than is the case with our well-insulated '52 MG TD, which lacks a heater. (I used 1/8" closed-cell foam on all interior surfaces when I restored the car 15 years ago--it gives the vinyl a "soft-touch" feel that certainly isn't original but is appreciated).
Display Modes
