Old 05-08-2010, 02:13 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Default Jag Power Lock torque spec and where to get bolts
Gents,
I am going through a 70's Jag XKE Power Lock differential. I am using both the Jag manual and a Dana manual.
I disassembled the Power Lock to look at condition of the clutch packs while I was putting in new seals.
My mistake came when I used the Dana manual for the torque spec on the bolts that hold the two halves of the Power Lock together. It specified 65-70 foot pounds. Before I realized my error I stretched at least one of the bolts.
They appear to be grade 2, 3/8-16 x 2.75" long.
It is obvious the Dana Power Lock must use larger bolts than the Jag unit. Can't tell for sure since the Dana manual does not specify bolt size.
My questions are;
1. What is the correct torque spec for the Jag Power Lock bolts?
2. Where can I get the 8 bolts required? Is there anything special about them that is not obbvious?
Thanks.
John
Old 05-08-2010, 03:24 PM
lal Naja's Avatar
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
You can buy your bolts from McMaster Carr. Check out their catalog. I buy a lot of industrial items from them including all my Cobra hardware. Typically you can buy a standard box 50 to 100 count of nuts, bolts, washers, etc. for less than you would pay at a hardware store for a dozen.
Their service is fantastic. I'm in Chicago and I order from their website at night when I'm designing components and the next morning the items are at my door.
Grade2? bolts. I didn't think the diff would have anything less than grade 5 or 8. But I'm no diff expert.
Good luck,
Arthur
Old 05-08-2010, 06:17 PM
Tom Wells's Avatar
John,
Here's a guy who can answer those questions correctly:
http://www.cwiinc.com/contact.htm
Tom
Display Modes
