February 2026
Old 09-11-2010, 09:20 AM
Default Rear passenger blinker not working
Hi Bob
my rear passenger blinker will not light all others are functional i checked all the way back to fuse block and i have no power coming in to fuse block i looked at electric diagram and can't tell were the power is coming from.Need help.
thanks
Richie G
Old 09-11-2010, 04:34 PM
All the signal light power comes off the same fuse (bottom, passenger's side), so it's not likely that is a problem. (Note that that fuse is dead with the ignition switch off.)
Do you have brake lights on that side? If not, check the fuses on the bracket under the steering column.
There's a more thorough troubleshooting process in my "Wiring Primer".
Old 09-11-2010, 06:43 PM
Tommy's Avatar
On fiberglass body cars, the first thing I always check is the ground to the faulty light.
Tommy
Previously owned EM Cobra
Old 09-18-2010, 03:15 PM
Hey Bob my car # is 635 427 I looked under the passenger side and I do not have any fuses there, the fuses are under the steering column. All my lights work, parking ,brake even the front blinker works.I checked the grounds and they are good I do have the emergency light and reverse light setup in my car.thank you for the down load on the electrical wiring but did not help me.Need more help.
thanks
Richie G
Old 09-18-2010, 03:40 PM
Switch (interchange) the yellow and green wires on the fuses (just the pair on one side) under the steering column. Try the signal and brake lights.
What happens?
