Old 10-19-2010, 03:09 PM
ZOERA-SC7XX's Avatar
I had to cut my hardened fork to clear the tunnel flange but could not get the cutoff tool in there, so I used a Sawsall. Worked like a charm and didn't have to take anything apart. After you get your required clearance, mix up some epoxy and apply it to the worn area.
Old 10-19-2010, 04:29 PM
Ibr8k4vetts's Avatar
Just put in a small block and you won't have that problem!
Mike Z
Old 10-19-2010, 07:45 PM
cobred's Avatar
Maybe if someone holds the clutch pedal to the floor the fork will move enough to get a cutoff wheel or grinder in there. Then just leave the master alone if its not leaking.
Old 10-20-2010, 07:31 AM
Maybe you could remove the slave cylinder rod to allow the spring to pull the fork as far forward as possible. Then if it moves forward enough you could get in there with a small cable drive Dremel attachment & grind the end of the fork the required amount.
With the fork in place you would be able to move it by hand back into position & check for clearance.
Craig
Old 10-20-2010, 08:33 AM
Here's a better shot of the rub. The previous photo was a little deceptive on the angles. It will be impossible to grind/cut the end of the fork without removing the master cylinder first, and it doesn't matter whether the fork is forward or back in that regard. What I ended up doing for now, while I wait for a new plastic inlet from Tilton, is to mark the rub area with a black magic marker to see if it is still rubbing or not. I'll try and get the car out for run when the weather improves.
Old 10-20-2010, 09:06 AM
The plastic looks very, very think in that top picture.
It's probably worse at a low rpm than at a higher rpm or higher load, because of the way the engine moves under load.
Old 10-20-2010, 09:07 AM
RodKnock's Avatar
As you get older and shrink, maybe you when you're 6'2" or less, you can move the master cylinder back where it should be.
Why not make this a Winter project for yourself and R&R the whole thing?
Old 10-20-2010, 09:18 AM
kgs365's Avatar
is the additional roll bar causing this rub?....sorry...maybe i should just say yes...i'd replace it!...it can't more then a $20.00 piece of plastic that would cause nothing but grief when it brakes
Old 10-20-2010, 09:42 AM
Cobra Make, Engine: ERA #776, 445 FE
I think that's probably exactly what I'm going to do. I only need to cut a piece of the fork about the size of a thumbnail.
I did the same thing on mine with a cutoff wheel. It was a bit of a pain getting the correct angle without cutting something I didn't want cut, but it worked out fine without taking anything apart.
Old 10-20-2010, 10:01 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Way better picture. That nylon is down to the quick. You know what you need to do. Remove the entire drivetrain.
But it's creeping over time, don't you think? It's not like the fork took all that off at one time. Plus, the nut doesn't seem centered on the fork anymore.
rodneym
Old 10-20-2010, 10:05 AM
Patrick,
I have a Wilwood unit which I think is the same one as the Tiltons use. You don't have much plastic left there as you probably already know.
If you need one, I have a couple spares. I could drop one in the mail for you if you need it quickly.
Old 10-20-2010, 10:06 AM
Thanks Bob, but Pegasus has already shipped one out to me. I know I have to take everything apart and replace it. But...
Originally Posted by cdnus View Post
... you could get in there with a small cable drive Dremel attachment & grind the end of the fork the required amount.
Craig, I stuck "can my Dremel cut through case hardened steel" and this little blog popped up with photos. http://blog.daveduncan.ca/?p=2274 Having a relatively small, easily controlled tool like my Dremel could make this job a heckuva lot easier than I first thought....
  #33 (permalink)
Old 10-20-2010, 10:16 AM
Z-linkCobra's Avatar
rodneym
You need to pay real close attention to this post...he's right that did not happen in one swipe. Something is moving side to side down there that is probably going to get worse as time goes on.
Good catch Rod.
  #34 (permalink)
Old 10-20-2010, 10:33 AM
Good catch Rod.
I went back and checked my archives. It's been doing this for years. I just caught it though on my inspection this week. Here's a shot from when the car was literally brand new. What also irritates me is that I bet I've looked directly at that wear a couple of dozen times and still didn't see it.
  #35 (permalink)
Old 10-20-2010, 10:35 AM
rodneym's Avatar
Full Blown Member
Premier Contributor
Good catch Rod.[/quote]
FINALLY!!!
My head hurts.
  #36 (permalink)
Old 10-20-2010, 10:42 AM
dcdoug's Avatar
Craig, I stuck "can my Dremel cut through case hardened steel" and this little blog popped up with photos. Having a relatively small, easily controlled tool like my Dremel could make this job a heckuva lot easier than I first thought....
I use a cut-off wheel in my rotozip all the time. 30,000 rpm = knife through butter.
www.partskeeper.com
  #37 (permalink)
Old 10-20-2010, 10:44 AM
It would never have occurred to me that my Dremel would cut through my clutch fork. Makes me appreciate the fact that Jamo hasn't kicked me off this forum....
  #38 (permalink)
Old 10-20-2010, 11:10 AM
RodKnock's Avatar
Personally, I would sell the car. Too many issues.
  #39 (permalink)
Old 10-20-2010, 11:11 AM
Those little buggers will cut almost anything steel, but are VERY fragile.
They will explode in a heartbeat if jammed up at all, be sure to wear protection (for your eyes )
If you have access problems with the dremel, have a look at the cable drive attachment. It will get in much tighter places.
Craig
  #40 (permalink)
Old 10-20-2010, 11:40 AM
I'm shocked you're not praising me for having the eagle eye to have spotted this before it left me stranded.
Craig
Got it. I think I'll have plenty of room once I remove the master cylinder, and I think I would probably do that anyway to get that plastic inlet on the top of it. Uhhh, I guess I should take pics?
EDIT -- Cable Drive, hmmm... Man, I love an excuse to buy a new tool.
