  #41 (permalink)
Old 10-20-2010, 12:27 PM
Makes me appreciate the fact that Jamo hasn't kicked me off this forum....
11,674.
We live in hope.
Chas.
  #42 (permalink)
Old 10-20-2010, 12:29 PM
11,674.
We live in hope.
I love it.
  #43 (permalink)
Old 10-20-2010, 12:38 PM
Seems like you might need to order the "Clutch Fork-to-Master Cylinder Separation Tool."
  #44 (permalink)
Old 10-20-2010, 12:42 PM
If there is even the slightest need for that cable drive off the end of my Dremel I'll happily get that... and then offer to check ERA Chas' prostate with it.
  #45 (permalink)
Old 10-20-2010, 12:45 PM
I HAVE a Dremel cable drive which I was about to offer for your use...
until this UNFORTUNATE remark.
Chas.
  #46 (permalink)
Old 10-20-2010, 12:57 PM
Did someone confirm that the Dremel wheel will actually cut it? I have never seen such hardened steel. I had to have a machine shop chop off the end and reposition the slave rod hole and they even squealed about how hard it was to cut and drill.
  #47 (permalink)
Old 10-20-2010, 12:59 PM
Here's where I unsubscribe to this thread.
  #48 (permalink)
Old 10-20-2010, 01:00 PM
HI Cobra's Avatar
A Dremel with a diamond tip might get the job done too. There are a lot of different sizes and shapes for just about anything. I got a 50 piece set from Harbor Freight a while back for under $20. Might be easier than a cut off wheel.
Flip
  #49 (permalink)
I see that Dremel sells a diamond studded wheel, but I'm going to try the reinforced ones first. They also sell tungsten carbide stuff.
  #50 (permalink)
Old 10-20-2010, 01:12 PM
I'd be putting on one of these first:
  #51 (permalink)
Old 10-20-2010, 01:20 PM
OOOOHHHHH!!!
you opened a whole bunch of doors for Chas with that
  #52 (permalink)
Old 10-20-2010, 01:27 PM
Just tryin' to help a brutha out.
  #53 (permalink)
Old 10-20-2010, 01:33 PM
His head would NOT fit into that.
Chas.
  #54 (permalink)
Old 10-20-2010, 02:36 PM
Had you been thinking you would have added something to the effect that " while the helmet would not fit, the point on the top is appropriate."
  #55 (permalink)
Old 10-21-2010, 04:54 AM
RAO-3's Avatar
Cobra Make, Engine: ERA #775
I have heard that putting super glue on the cutoff disks makes them less likely to break. May want to give that a try as well.
-Ray
  #56 (permalink)
Old 10-21-2010, 10:46 AM
-Ray
Dremel has these new fiberglass-reinforced cutoff disks that they say are designed for hardened steel, so I picked up a 20 pack of them. They're made out of depleted uranium or the like I'll probably start the heavy lifting tomorrow or this weekend, so I'll let you know. I also picked up a tungsten carbide blade as well -- Dremel says it's also suitable for cutting hardened steel.
  #57 (permalink)
Old 10-22-2010, 08:29 AM
Default Well That Was Easy...
I didn't need the 20 pack of the depleted uranium disks. One did the trick astonishingly well. It was like using a dang plasma cutter. Here, I took a shot 30 seconds (maybe less) in to the cut. The second shot is of the corner entirely removed.
  #58 (permalink)
Old 10-22-2010, 09:15 AM
RodKnock's Avatar
Can you make it look a little nicer? You'll never make it as a sushi chef.
  #59 (permalink)
Old 10-22-2010, 09:20 AM
Seriously, take the sharp edges off and round the corners. You don't want cracks to begin. Put a tootsie roll on the Dremel or use the flat face of the cutoff wheel if you have to.
Chas.
  #60 (permalink)
Old 10-22-2010, 09:22 AM
Alright, alright... I'll clean it up a bit while I'm waiting for the new remote inlet to arrive. Sheeeshhh....
