Old 03-31-2011, 04:49 PM
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
Default Back Up Light
California DMV requires a back up light.
Where are you mounting one on an SC?
Drink no wine before its time
Old 03-31-2011, 05:12 PM
RodKnock's Avatar
Steve's (PANAVIA) writing isn't CA law, and it may not be current to 2011, but I'll take a quote from it:
"Let them know you are asking to be tested as a 1965 motor vehicle, this will
dispense with the needs for “Side Marker Lights” and “Reverse Lights”, which were required in 1968 and 1966 respectively."
http://www.newmustangranch.com/SPCNS.pdf
Old 03-31-2011, 05:59 PM
If you really have to have one, then just bolt (or even zip tie) an ATV reverse light like this one: http://www.warn.com/atv/lights/ATV-BackUpLight.shtml to either your rear bumper or quickjack and then remove it after your inspection. The reverse switch on the more modern transmissions, like the TKO, are as simple as it gets and you can wire it up in a few minutes.
Old 03-31-2011, 07:01 PM
boxhead's Avatar
Here is what I did, it is bolted to the quick jack, the red reflectors have "fallen off"
But the light hasnt yet.
Cruising in 5th
Old 04-05-2011, 12:28 PM
289fia_cobra's Avatar
I had a jackass inspector that insisted I have TWO backup lamps. I did install an older Mini-Cooper backup lamp under the trunk latch.
Got two trailer style units, some scrap aluminum and hooked them both up to my tranny switch:
Afterwards, I removed them and have been running around with just the one Mini-Cooper lamp.
BTW: I have two trailer lamps with brackets if anyone wants them to pass inspection!!!! PM me if you really want them.
My Build Site
Old 04-05-2011, 03:51 PM
mln385's Avatar
Cobra Make, Engine: BDR
Went to auto store bought one clear lense fixture and some velcro, then attached velcro to underside of gas tank and light.
Been there for three years hasn't fallen off yet.
