Old 09-24-2001, 01:39 PM
Cammer's Avatar
Cobra Make, Engine: ERA 427 SC - #463 - 427 SOHC
Default Noise???
Bob,
I have been noticing an intermittent squealing noise coming from what seems like the clutch/trans area of my car - it gets louder when cruising as the rpms rise and then it gradually goes away when coming to a stop and depressing the clutch pedal - any ideas - throw out bearing ??? What???
Old 09-24-2001, 03:28 PM
It sounds (no pun intended) like the throwout bearing. If you are using a return spring on the release lever, increase the clearance a bit. If you aren't using a return spring, add one.
If neither of the above actions help, try carefully spraying penetrating oil onto the sleeve that the throwout bearing slides on, and pumping the clutch pedal. Maybe some dirt or congealed grease is preventing the bearing from returning properly.
Hopefully, it's not too late.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
