Old 09-10-2011, 01:49 AM
Jeff Frigo's Avatar
Cobra Make, Engine: ERA 454 S.O.
Default Side Pipe Removal, Installation
Is it possible to remove the side pipes without removing the header pipes? How about the reverse process?
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
Old 09-10-2011, 05:21 AM
Sure. Just remove the four bolts holding the tabs together and the rear mount. Then curse a bit while simultaneously pulling the pipes apart and moving the back end around. But, it's easier if you loosen the primary pipe bolts.
Putting the pipes back on, it's mandatory that the primary pipes are loose when you mate the side pipes.
Old 09-10-2011, 07:17 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Ditto what Bob said. Took mine off a few years ago and had no problem getting them off or putting them back on.
Definitely loosen the primaries to allow the pipes to move a little bit at the joint. With my big block I couldn't really get to the bolts securing the rear primary on the driver's side but it didn't cause a problem as long as the other three could move a little.
DonC
Old 09-10-2011, 07:33 AM
Kramer's Avatar
Cobra Make, Engine: ERA 739
Yes...just I just did it recently. I used a little WD40 to get them off and a little grease when I slid them back on.
Old 09-10-2011, 10:17 AM
cobred's Avatar
Cobra Make, Engine: ERA #698 428 Toploader
I have 2 sets that I switch back and forth. I never had to loosen the primaries, you may cause a header leak. I just pull on the front while I wiggle the back up and down and in and out an inch or two.
Old 09-10-2011, 03:18 PM
It's actually amazing to me that the primaries almost always line up so well. right out of the box. At any rate, after the initial installation and the car is run, the pipes will relax a bit, so on subsequent installations they will fit a little better.
Old 09-11-2011, 11:22 AM
Kramer's Avatar
Agree with both of the last two post
Old 09-11-2011, 03:28 PM
ZOERA-SC7XX's Avatar
When I first put my pipes together, I used plastic wire ties on the loose primaries to hold them together down near the ends, each tie holding two pipes. Worked like a charm.
