November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 10-11-2011, 08:22 PM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Pedal Set Screws
Bob,
A few years ago I was speaking with Doug about some free pedal play and he said to check a set screw or two in the pedal assembly. I believe he was referring to the horizontal shafts. Can you tell me more about what to check? Are these set screws found inside the car or in the master brake box under the car.
Thank you
Old 10-12-2011, 05:55 AM
I bet he was talking about this:
Old 10-12-2011, 06:11 AM
There's a set-screw on the inner end of the cross-shaft that secures the clutch arm. On the other end, there's a shoulder bolt.
Old 10-12-2011, 06:18 AM
Which was the subject of this famous thread, replete with pics: Ehhrggg, Standed by a Set-Screw
Old 10-12-2011, 09:53 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
You've got to get the car up in the air and take off the pedal box/cover to access one end of the shaft. The other end is connected to the clutch master cylinder adjacent to the frame rail.
Jim
Old 10-13-2011, 06:32 PM
Default Many thanks
I will be checking both set screws very soon.
Cobra 29
Old 10-13-2011, 06:57 PM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
Another area to check is the hole in the clutch arm where the master cylinder clevis attaches. I had clutch pedal free play at about 36,000 miles on ERA2041, and traced it to an elongated hole in the clutch arm (apparently due to lack of any assembly lube by the first owner ?). Bob sent me a new arm and pin, which I greased and reassembled. Don't forget to loctite the setscrew.
