November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
  #21 (permalink)
Old 04-09-2012, 09:40 PM
tkb289's Avatar
... As far as I know it should clear the hood fine but until I get it in there I can't be 100% sure. ...
Dan
Dan,
An easy way to check is get some silly putty and make small mounds about 1/2" thick, that you place on the air cleaner where you think there will be interference. Lower the hood till almost closed, then check. If ok, keep going till the hood is closed and latched.
Very likely some of the silly putty mounds will be squished just a bit, and you can measure the thickness to give you an idea of how much clearance you actually have. If it's ok, repeat the test with the motor on and blip the throttle to get the motor to torque over a bit, remeasure the silly putty.
I am sure Bob can provide a number, but I would suspect one would want at least 1/4" to 3/8" minimum clearance.
289 FIA --- ERA 2136
Build Log:
http://www.clubcobra.com/forums/era-...build-log.html
  #22 (permalink)
Old 04-09-2012, 10:06 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
DanEC: I honestly don't remember if my rotors came with the bearings. I do remember packing them with grease. I think they came with the kit. Best to just call Bob or Doug at ERA.
Have fun with your build!
DD
Dangerous Doug
"You're kidding, right?"
  #23 (permalink)
Old 04-10-2012, 05:53 AM
RAO-3's Avatar
Cobra Make, Engine: ERA #775
FWIW, not a rattle or squeak on mine....
Ray
  #24 (permalink)
Old 04-10-2012, 06:25 AM
DanEC's Avatar
DD
There was a front suspension hardware kit option (bearings, seals, dust caps and spindle bolts) that I overlooked when I ordered my car and the bearings are in it. Talked to John at ERA yesterday and he is fixing me up.
I thought that bearings and the bearing race were usually matched up and replaced/sourced together - maybe I'm wrong about that. I did have the dust caps and spindle nuts/washers with the car. I think it would make sense to supply the bearings with the complete front end but its no big deal.
Thanks
Dan
  #25 (permalink)
Old 05-03-2012, 02:14 PM
Fullchat289's Avatar
Cobra Make, Engine: ERA FIA #2124
Dan...just wanted to get back regarding the post I made earlier in this thread. After driving the car, I can confirm that my annoying "dash" squeak has gone away with the addition of the foam rubber between the front of the radiator and the filler piece at the front of the hood opening. My car is "tight" now...
- Allen.
  #26 (permalink)
Old 05-03-2012, 05:41 PM
Snakebit's Avatar
Club Cobra Member
Cobra Make, Engine: ERA 289 FIA #2100 Rio Red Wimbledon White Stripes 302 stroked to 331 Webers Richmond Road Race 5 speed
If you hear any rattles and squeeks, your pipes aren't loud enough!
Snakebit
Display Modes
