Old 09-09-2012, 09:48 AM
bliss's Avatar
Default Access to Transmission
It appears that my transmission has a leak and I need to access it - there is a bar that goes across the bottom - so, it appears that access is from the floor of the interior (I'm a driver, not a builder).
Could someone point me to the steps required to access the transmission?
Old 09-09-2012, 10:33 AM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
This can be done with the car on the floor. Remove seats (4 bolts each from underneath). Remove shifter boot and handle. Remove the E-brake boot. Remove sheetmetal screws from tunnel along sides. They can be accessed just under the carpet edge. Remove tunnel (it takes a little patience). This will expose trans, driveshaft, and E-brake. You should be able to adjust the E-brake here. Good to grease the U-joints while you're in there.
Old 09-09-2012, 02:37 PM
bliss's Avatar
Thanks, that should work well.
Old 09-09-2012, 05:34 PM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
I don't know about your car, but on the later cars, there is also an inspection/access plate at the rear of the transmission cover that has to be removed before you can pull the trans cover. It has about a half-dozen screws. There may also have to be a little attention around the roll bar if you have one.
Display Modes
