Old 12-22-2012, 07:05 PM
Default Metric or standard for ERA assembly?
Once my car comes, will I need mostly metric or standard tools for assembly? Thanks.
Old 12-22-2012, 07:53 PM
Fullchat289's Avatar
Mostly all standard for the ERA designed items. The metric stuff you will run into will be on any GM stuff that's on the car...for instance, the F-body Rear brake calipers use a 15mm socket on the upper caliper bolt and a 17mm hex on the slider pins...I know this b/c I just changed pads today. You may also need a variety of Allen wrenches. If you opt'd for the ERA rear suspension, it uses a 3/8" Allen key bolt at the bottom attachment points....the seats and fuel filler also use Allen wrench bolts...at least that was the case on my car.
Have Fun!
- Allen.
Old 12-23-2012, 04:07 AM
Mr. Chat is correct. All the body, chassis and suspension components are USS. The late rear outboard brakes are metric. And the banjo bolt into the clutch slave cylinder is metric too...
Old 12-23-2012, 05:00 AM
427 Street's Avatar
Cobra Make, Engine: ERA #472, Previous owner of ERA #677 427, ERA 289 FIA-USRRC Street
My car is all SAE/Standard.
"Some things get meaner as they get older."
Old 12-23-2012, 06:43 AM
IIRC, the bleeder screw on the clutch slave required a tiny metric box wrench....
Old 12-23-2012, 07:07 AM
..7mm.
Chas.
Old 12-23-2012, 07:21 AM
427 Street's Avatar
Good to know....I never touched that....yet
Old 12-23-2012, 05:05 PM
ERA 778's Avatar
Cobra Make, Engine: ERA #778 427SC Keith Craft FE 428 stroker
Yes, 7 mm. I remember having to crawl out from under the car several times before I got it right. Was expecting SAE!
Old 12-23-2012, 05:31 PM
I have pretty much every tool I need including the metric ignition wrench for the bleeder. But it is still an excuse to buy a few more
Old 12-23-2012, 06:18 PM
DanEC's Avatar
Here are a few more you might want to make sure you have on hand.
A hard rubber mallet
A rivet tool (pneumatic if not having ERA bond and rivet the body to the frame)
A set of SAE T-handle allen wrenches (they use a lot of allen head fastners)
A heat gun (useful for many purposes)
A set of 12-point sockets (3/8 inch drive) for all the ARP fastners on most engines
Possibly a riv-nut tool and assortment of riv-nut inserts.
You can never have too many tools.
