Like Tree3Likes
Old 11-20-2013, 09:44 AM
If you don't trim it, it will be awfully close to the ground. With the rpms that engine will turn, and with there only being a little bit of fiberglass between you and the flywheel, I would at least go with the trimmed Quicktime. No aluminum.
I know someone who can get you a good deal on a QT... You need an RM-6065.
ERA Chas likes this.
Old 11-20-2013, 09:47 AM
BTW, if you change distributors, lock the timing out, and make sure that the new distributor has a steel gear on it.
Old 11-20-2013, 09:58 AM
xlr8tr's Avatar
Cobra Make, Engine: CAN-AM cobra, 460 SVO
well thats all i have to do to lose probably 300+ lbs off the front end compared to my iron block/iron head 460... and probably gain in the lbs per HP category too!
Originally Posted by ERA2076 View Post
Mark
Old 11-20-2013, 10:29 AM
Cobra Make, Engine: ERA - B2Motorsports Dart 331
I thought ARP was the stuff.
Old 11-22-2013, 05:18 PM
Default QuickTime SFI
33 lb
Old 01-24-2014, 02:27 PM
Jag -
C4
Oz
Old 02-03-2014, 05:47 PM
Howe Racing 3/4" x 8" Collapsible x Quick Disconnect
Old 02-03-2014, 06:18 PM
You did weigh the complete car before you tore it apart---right??
Chas.
Old 02-03-2014, 06:47 PM
2440 lb
Old 02-17-2014, 11:40 AM
Wilwood
Old 02-17-2014, 12:00 PM
Trick-and weight off the best place.
Chas.
Old 02-26-2014, 06:04 PM
Dominik's Avatar
Is there a chart comparing tire weights?
Differences can be drastic, i.e for BFG vs Hoosier.
Nice going by the way, to weigh all parts. I built my car in the 90s on bathroom scales!
Needed 8 of them :-)
Aim to save as much as you can for rotating weights.
  #33 (permalink)
Old 03-05-2014, 11:29 AM
Trade - Piston area reduced from 5 to 4 sq in
Steel
Aluminum
  #34 (permalink)
Old 03-05-2014, 06:03 PM
1985 CCX's Avatar
Maybe I missed it, driver?
  #35 (permalink)
Old 03-05-2014, 06:39 PM
165 lb
  #36 (permalink)
Old 04-07-2014, 02:39 PM
PowerMaster
  #37 (permalink)
Old 04-07-2014, 04:49 PM
  #38 (permalink)
Old 04-07-2014, 06:55 PM
You need an adjoining scale which measures dollars spent vs pounds removed.................
Chas.
  #39 (permalink)
Old 04-07-2014, 07:51 PM
nah - Purchasing used helps a lot. There is some pretty good margin between purchasing used and a new roller. I got a great platform and I get to build what I want.
Building a Cobra with Shelby weight (not sure I will make it, but not for lack of trying), ERA chassis, ERA suspension, aluminum engine, and lite weight gearbox is a very gratifying thing to work on. I am fortunate I have the means and it makes me smile every time I see it. . I waited I long time to get the opportunity and I am enjoying every minute. That it is 12 years old just makes it that much better for me.
I intend to enjoy it for years to come .
- unless it turns out to be a complete POS.
chr
  #40 (permalink)
Old 04-08-2014, 09:51 AM
xlr8tr's Avatar
Great process- what are you hoping it will end up at for total weight?
Mark
