November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 06-18-2014, 11:18 AM
Default What size mufflers ERA SS side pipes
What size are the mufflers and does anybody know if a Backdraft heat shield will work/fit, or does ERA make a nice heatshield?
Old 06-18-2014, 02:35 PM
The normal side pipes are 4" in diameter. That's probably pretty standard. It's possible that the Backdraft pipes are from 100mm tubing: 3.94" equivalent.
Old 06-18-2014, 02:50 PM
My car has the "abnormal" SS ERA sidepipes. Still 4" diameter?
Old 06-18-2014, 04:00 PM
kevins2's Avatar
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
If by "abnormal" you're talking about the "Quiet" pipes, yes they are 4" diameter. The baffled part of the side pipe is simply longer than the standard pipes. I have the ss quiet pipes and the 4" diameter baffled area is 28" long.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
Old 06-18-2014, 08:39 PM
Kevin
Yes, Kevin. Thank you. I'm waiting for my car to arrive, but will need to have it inspected. They will most likely want to see it with heat shields installed for the inspection.
Old 06-18-2014, 05:38 PM
Cobra Make, Engine: BDR, 302
I replaced my stock BDR side pipes with 4" stainless specialties mufflers. The BDR beat shields went on with no problem. The straps have plenty of adjustment.
Old 06-19-2014, 06:45 AM
kevins2's Avatar
I'll send you a pm regarding an alternative.
Kevin
