Old 10-05-2014, 10:16 AM
bliss's Avatar
Default Trunk Lid Adjustment
I was working on my tail lights issues - had the trunk lid open for about a week - tried to close it and suddenly it's 'off' about 1/2 inch....
(I've placed a towel on the right side - it's paint to paint with the lid off perhaps 1/2 inch to the right side)
Just Damn!
Anyway, it seems like something slipped but I don't see anything that would be subject to slipping. I loosened the bracket bolts (they were already a little loose) that are attached to the car to see if there was any available adjustment - a little wiggle room but basically no luck.
Once again, I'm totally discombobulated by this problem - it's as if I've entered the Twilight Zone in which nothing fits.
Are there ways to adjust the trunk lid - front to back, etc.?
Any input will be appreciated.
Old 10-05-2014, 11:25 AM
No chance somebody tried to close the trunk with the stay extended and twisted the brackets, right? If not, then (from the manual):
Bolt the trunk hinges (they are marked with a T on the lid side) loosely onto the body with any shims found earlier. Loosely bolt the trunk lid (with factory shims) onto the hinges. Carefully close the lid, not letting the front edge contact the body. Center the lid in the opening. Slowly lift the lid just enough to get your arm (and a wrench) inside and snug the bolts on the lid part of the hinges. Remember to check the front edge while lifting lid. The lid can be adjusted further by moving the lid and hinges in unit at the connection on the inner panel. Tighten bolts and recheck fit.
Old 10-05-2014, 02:41 PM
We've left trunk lids open for days at a time without a problem. I suspect that the latch is doing something strange to the alignment.
Old 10-05-2014, 03:03 PM
DanEC's Avatar
If not as Bob suggested, then I suspect the hinge bolts to the body slipped, although it could be the bolts to the trunk lid. First thing is to put a layer of blue masking tape on all edges to protect the paint. Then loosen the hinge bolts but leave one of them snug enough to hold but allow you to shift the trunk with minor effort. Wiggle the trunk into alignment and carefully, carefully lower it to check alignment. If it looks like it's going to hit anywhere then stop, raise it up and wiggle it around a little more until it fits right. The other option is to con a small child to climb inside with a flashlight and allen wrench. Loosen the bolts, set the trunk lid in position and tell the kid to tighten the bolts. Good luck with this one.
ERA 782 Running
Old 10-05-2014, 09:41 PM
spf645's Avatar
Cobra Make, Engine: Superformance, 351w
DanEC,,
Best one I've heard all day. Thanks for the laugh. Though I feel sure this idea has been done before. But I'm not admitting anything!
Old 10-06-2014, 12:33 AM
aaannnd's Avatar
Cobra Make, Engine: EASER/pilgrim sumo, 2.9EFI V6 FORD
other option, i suppose it's a fibreglass lid, so don't touch hinges setup, open the trunk lid, lose boot stay and put a stick on the opposite side of the lid, and stay open for another week
Thats an option if you have not enough laugh.
Old 10-06-2014, 04:51 AM
DanEC's Avatar
After looking at the pictures more and considering the trunk prop - I bet the bolts on the pass side securing the trunk lid to the hinge are loose and slipped.
ERA 782 Running
Old 10-06-2014, 07:33 AM
kevins2's Avatar
I agree with Dan - you mentioned the bolts were a bit loose so they probably slipped. The trick to aligning it, other than having a small kid in the trunk, is to spend a little time getting the bolts adjusted loose enough so you can move the alignment but tight enough so they won't move when you're raising and lowering the lid to test the alignment. That way, you can jockey it around until it is properly aligned and then tighten down the bolts. Tighten each bolt a little at a time to prevent the lid from moving.
Kevin
Old 10-08-2014, 10:52 AM
bliss's Avatar
Thanks for all the input.
It turns out that one of the hinges was bent. I've no idea how it happened since a lot of force would need to be applied to make that happen - I didn't use force in any way - once again it's a twilight zone event or mystery that remains unsolved.
The bottomline is it's fixed.
Old 10-08-2014, 10:57 AM
Originally Posted by bliss View Post
It turns out that one of the hinges was bent. I've one idea how it happened since a lot of force would need to be applied to make that happen - I didn't use force in any way - once again it's a twilight zone event or mystery that remains unsolved.
It is a phenomenon known as "garage elves." Funny thing is, the more kids you have around the house, the more mischievous elves you seem to have.
