1Likes
Post By rbtrader
02-22-2017, 07:27 PM
Source for wire wheel adapters
I would like to convert my ERA slabside to wire wheels. It currently has a spinner kidney bean alloys. I talked with Peter at ERA and he says they made some that they want to save for their builds.
There is a shop in England, but there has been a long delay in getting them to take my measurements and spec out an adapter. Does anyone have any other source to get adapters made so I can put 17" x 5" Dunlop wire wheels on my car? Dunlop only suggests the shop in a England.
Thanks in advance.
02-22-2017, 07:31 PM
17" x 5" wire wheel?
Alba gu brąth
02-23-2017, 05:03 AM
It all depends on your wheel offset. The most available off-the-shelf adapter that fits our hubs is from an Austin Heally 3000. The offset is about 1/2" too far out for the original 6" wire wheel, which is why we don't use it. If you have a way to display a DXF file, I can send you my drawing - which is not dimensioned.
02-23-2017, 06:28 AM
Correct Wire Wheel Size
I am sorry, my prior post was in error. I want to use Dunlop 15" x 6" with a 42mm center. I think I must have been in a daze when I sent the prior post!
02-23-2017, 06:34 AM
DXF file
Strictlypersonl,
Please send me the file, and I can use a DXF viewer app to see it. Thanks!
Rich
02-23-2017, 06:59 AM
Do you have an old set of Dunlop wheels? I've heard of fitment issues with current Rudge splines and old Rudge splines. Dayton makes a close copy of the well-laced 6" wheel and I'm told fits modern spline hubs better. Just something to check as you fit them.
Alba gu brąth
02-23-2017, 07:01 AM
In
Cobra Make, Engine: B & B 289
adapters
Do you have a print of the adapters? If so, send it to me and I will see if we would want to make a set for you. pat@moldshop.net
02-24-2017, 04:47 AM
02-24-2017, 07:32 PM
Thanks for the offer to try to machine some adapters for me, and thanks for the helpful DXF files. I am currently out of the country, but I return home this weekend. I will get back to both of you after I have had a chance to review everything.
02-26-2017, 11:47 AM
DXF File for ERA hubs
Bob, Thanks for the two DXF files, it makes the adapter issue a lot clearer. Is the DXF file for the ERA Hub the adapter that would work with Dunlop wire wheels? If so, those are the adapters I need to have made. Please clarify what the adapter specifications and drawing in that ERA Hub file mean.
Thanks, Rich
03-02-2017, 04:41 PM
Yes
Thanks, Rich
Any proper machinist should understand the base metal specifications. For the threads, I typically give a sample for the machinist to duplicate.
