Like Tree3Likes
Old 04-24-2020, 06:24 AM
PCW PCW is offline
Originally Posted by strictlypersonl View Post
It's in the volume behind the left rear wheel. There is a panel equivalent to the one in front of the battery. It's held in place with a few bolts that can be seen from the front. The biggest challenge will be bypassing the normal fuel line path into that area.
Bob, sent you a PM.....
Old 04-24-2020, 12:19 PM
Cobra Make, Engine: ERA FIA 2158, ERA 427SC 649 sold
Both Edelbrock and FiTech make a tank with a high pressure pump inside that looks easily mountable. Let me know what you end up doing as I will be in the same boat when I build mine.
Old 04-24-2020, 05:44 PM
Tom Wells's Avatar
I know I'm late to this
I've used this: https://aeromotiveinc.com/product/ph...h-fuel-system/ in my HSMobile. It works great and isn't too tall. It also has an engineered baffle which keeps fuel at the pump intake when cornering or otherwise inducing G-forces.
If removing the tank isn't too difficult, and there's a little clearance above it, this can be a really good solution.
A couple of photos:
Old 04-25-2020, 07:32 AM
Cobra Make, Engine: ERA 289 FIA 351Windsor
I just saw this thread was resurrected and thought I'd share what I did for my conversion. I removed the tank and had a bung welded in the area suggested by Bob. I used the original fuel line as my return and ran the new supply line on the right side of the car. Here's a photo of how I configured the pump and filter. I gave up on the in-tank option because there is very little room on the top of the tank to run fuel lines. A custom tank would be necessary with a shorter profile to use a top mounted fuel pump.
I wouldn't put a surge tank in the wheel well. Too exposed to possible damage from the rear wheel if things got ugly.
Note: I had trouble uploading the photo for some reason. Not sure why, it's a jpeg and not too big. Maybe someone has an answer? Send me your email and Ill send you the photo.
Kim
Old 04-25-2020, 09:09 AM
PCW PCW is offline
Kim
Thanks Kim, I PM you my email. If possible do you have a photo of where the bung was welded on the tank?
Thanks again!!!
Craig
Old 04-26-2020, 08:52 AM
You're welcome! Good luck with your build! And stay with the 289...a much cooler car IMHO...
Here's a photo of the EFI conversion and my mechanic. She did the entire conversion with that one wrench!
PCW likes this.
