Old 01-16-2002, 02:48 AM
Cobra Make, Engine: ERA 427SC FMS 351W
Default Red Dash Light
What does the red light (beside the ignition key) indicate? My occassionally comes on when I am on the brakes and the RPMs are dropping. After the car stops and the engine is at idle the light will go out.
Old 01-16-2002, 03:27 AM
luc's Avatar
luc luc is offline
Here is my opinion ;
There are two possibilities .
1. Can be your charging system ( battery not charging at low RPM)
2. Can be the light connected to the Master break cylinder (Brake fluid level too low)
Luc
All the best from Belgium.
Old 01-16-2002, 04:43 AM
Early cars used a switch in the brake reservoir cap that indicated low fluid.
Later cars have a system that shows when there is brake pressure at one end of the car but no pressure at the other. Sometimes a defective brake light switch will do this too.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 01-21-2002, 09:16 PM
Turk's Avatar
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
Bob,
My red light used to come on and now it finally stopped. If the bulb is not burned out, does it make sense for it to have fixed itself, or does it mean something else?
TURK
OBAMA IN in 2012
Old 01-22-2002, 04:04 AM
If the pedal is high, the light coming on is usually an indication of a bit of binding in the balance bar. Yours probably is just properly broken in.
Bob Putnam
-E.R.A.-
