Old 07-18-2018, 12:36 PM
PeteF's Avatar
Cobra Make, Engine: ERA2041 sold 2021
Default Fan thermo switch part number
Can someone (hopefully Bob) tell me the part number of the fan thermo switch located in the lower radiator hose. Mine has apparently died. The fan works with the dash switch and also when I jumper the switch leads. I can't find it in the manual. Thanks
Old 07-18-2018, 12:47 PM
Default Right outta the manual...
Switch, fan thermo -- 1980-1984 VW Rabbit, Jetta: 823 959 481/75
Old 07-18-2018, 02:42 PM
PeteF's Avatar
Thanks Patrick.
Old 07-19-2018, 04:54 AM
Section H of the manual has most of the interchange part numbers. If you download the PDF version of the manual, it's also easier to search.
Old 07-19-2018, 08:55 AM
PeteF's Avatar
Bob, My manual is Rev 1B, Nov '98 and only goes to Section F. Let me know how to download the latest PDF version for an FIA. Thanks
Old 07-19-2018, 11:17 PM
Dominik's Avatar
Those switches come in a wide variety of temperature when they switch on, in case you like to experiement a bit. Some have two settings (3 contacts). Your local store (NAPA??) should have them listed with temperature range.
If I don't respond anymore, that's because I can't log in
Old 07-20-2018, 12:27 PM
PeteF's Avatar
Yes, the one I have was working well, coming on around 190 degr F, so I'll stick with that. I found replacements online at two different websites. They are made by a company called Wahler, and were used in VWs and Porsches for many years, maybe still are. Thanks
