| S |
1 |
| 3 |
5 |
8 |
| 10 |
12 |
15 |
| 17 |
19 |
22 |
| 24 |
26 |
29 |
30 |
| 31 |
25Likes
04-09-2020, 03:30 PM
NJ
Cobra Make, Engine: Backdraft Car #1209 Roush 427R
Yes absolutely. Go for it. Please post the video. LOL
04-09-2020, 03:49 PM
Now, you know I'm not going to actually dangle my car from a crane, but this installation should be able to easily handle it, if I so chose. The installation is directly through the face of the quick jack, which is 1/4" thick steel. The tow hook is fastened with a 5/8-11 Grade 8 flange bolt. The bolt is welded to the back of the quick jack so that the tow hook is easily unscrewable and mountable to the rear quick jack as well or for storage in the glove box. The hardware fastening the quick jack to the frame is 3/8" B7 Alloy, which is roughly equivalent to Grade 5. That's easily upgradeable to Grade 8.
04-09-2020, 05:30 PM
Full Blown Member
....or, you can mount it to the top of your passenger roll bar.
Then lift with a crane and see if you can pull it right off.
You know, for Chas.
rodneym
04-09-2020, 05:39 PM
Here are two teaser pics to give you a rough idea of what it will look like after it's drilled and mounted. Obviously it will be cleaner and crisper when it's bolted through the face of the QJ. Yes, it will look cool.
04-09-2020, 05:49 PM
SA
Patrick,
I know you can't in the current environment, but really...you need to get out more
Stay sane
Glen
04-09-2020, 06:36 PM
... considering I've been towed up on to a flatbed once in the last 15 years.
04-10-2020, 12:07 AM
SA
You've been out once in the last 15 years and that was on a flatbed....?
