These are the 2 pins I’m talking about. The one on the left is the old clutch slave pin , the one on the right is the new style. The new one used a fork with a hole in it to ease adjustment.
Reason: Add picture
I had the fork with the hole originally but replaced it with the one in my picture above. I did keep the adjuster you show on the right and just shortened the rod since the hole is no longer there.
It is. Just don’t be too tempted to cut it shorter if it seems too long at first. I did just that and ended up having to buy another rod after I got the clutch all dial in.
