Like Tree2Likes
  • 1 Post By Grubby
  • 1 Post By Grubby
Old 05-24-2020, 06:38 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Default FE Expansion Tank Build
A small project assembling an FE expansion tank to keep me busy while I wait.
I purchased the unassembled kit and spent a few hours putting it together.
It needs pressure tested and painted. I need to pick up a valve stem to fab up a pressure test fixture.
Difficulty level 2 out of 5.
DanEC likes this.
Old 05-25-2020, 04:48 AM
DanEC's Avatar
Nice work. Anything special you soldered it together with?
I see a wheel in the background of the first photo that If I’m not mistaken, looks like a 19” Brembo wheel/package on a 11 or 12 Mustang GT. I had a 12 With the Brembo package that I traded in on a Shelby GT but I still miss that car.
ERA 782 Running
Last edited by DanEC; 05-25-2020 at 06:02 AM.. Reason: iPad doesn’t know what solder is.
Old 05-25-2020, 05:41 AM
undy's Avatar
I modified my tank for my KC 482. I was plagued with solder leaks afterwards. I disassembled the whole tank, cleaned all the soft solder off , fluxed and re-soldered it with 15% silver solder. 10+ years later not one leak.
Too many toys?? never!
Old 05-25-2020, 06:35 AM
Grubby's Avatar
I used 40% tin and 60% lead acid core and lots of flux. The solder flowed nicely and filled all the empty spaces. I pulled on the brackets pretty hard and they are solid.
Yes the car in the background is a 2012 Brembo car. It is currently my daily driver.
DanEC likes this.
Old 09-13-2023, 12:46 PM
Cobra Make, Engine: KCC Venom (BDR)
Default Modifying Galaxy/T-Bird tank
Undy, what specific tank did you modify and how difficult was it? I am contemplating modifying a T-Bird tank to have the outlet on the left. Is it difficult to desolder and can it be done with a normal propane torch?
Old 09-13-2023, 01:20 PM
twobjshelbys's Avatar
Acid core solder is not intended to be used on electronics. Rosin core or solid core with rosin flux (preferred) is for electronics.
CSX4005LA
Old 09-13-2023, 02:10 PM
Tony, Grubby is not soldering electronics.
Old 09-13-2023, 03:01 PM
Sorry I didn't go back far enough. I thought this was about something else.
PS. I'm surprised you can even find lead based solder any more for any application. I still have some in my stash.
CSX4005LA
Old 09-13-2023, 07:54 PM
sunman's Avatar
It’s available everywhere.
It’s guys that know what to do with it that are rare.
Chaney Shores Studio
Old 09-15-2023, 05:13 AM
undy's Avatar
Originally Posted by Cobra_ZA View Post
Undy, what specific tank did you modify and how difficult was it? I am contemplating modifying a T-Bird tank to have the outlet on the left. Is it difficult to de-solder and can it be done with a normal propane torch?
You have to de-solder every joint and clean every last bit of solder off/out of the joints. If you don't the silver solder won't bond. After that and the application of the required silver solder flux you'll need an oxy-acetylene torch as a propane torch doesn't produce adequate heat for silver soldering. After nearly 20 years after I did the tank I've had zero leaks. I was repairing leaks every couple weeks with the soft soldered joints.
Old 09-15-2023, 09:59 AM
You need one of these
CSX4005LA
Old 09-16-2023, 08:32 AM
Eight or 10 years ago I bought a new expansion tank from these folks:
https://classicfordradiator.com/61-6...sion-tank.aspx
I wanted to powder coat it but knew the solder melt temp was less than the powder coat cure temp. I 100% disassembled the tank, bought some lead-based solder, some flux and used Bernz-O-Matic propane torch. I melted off and cleaned off all the original solder and rebuilt the expansion tank with the lead solder. And then I powder coated it. No leaks these many years later.
[IMG][/IMG]
