Old 07-07-2022, 11:54 AM
Cobra Make, Engine: ERA 289FIA:289 8 stack
Default Tremec TKX install into 289FIA
Bob,
Has ERA installed a TKX into a chassis yet? It looks like a drop in replacement for the TKO so I figure that it would bolt right in like a TKO. I'm strongly considering a TKX and Quick Time bell for ERA-2164. I'll be bolting this all to a 289. I just want to understand any fitment issues including cross member/support, driveshaft length, clutch, etc.
V/r,
Sean
Old 07-07-2022, 04:08 PM
mrmustang's Avatar
Gold Star Contributor
Originally Posted by seatra View Post
Bob,
V/r,
Sean
Have not do one in a Cobra yet, but helped upgrade a big motor 92 mustang convertible recently, should be a straight bolt in.
Bill S.
Old 07-07-2022, 04:34 PM
Senile Club Cobra Member
Bill is correct, the TKX is a dimensional clone of the TKO 500/600. A nut and bolt swap.
rick@autoventureusa.net
Old 07-07-2022, 05:23 PM
I have never seen a TKX live and in the flesh, but I do know that the TKO has a boss on the right side that you have to grind off flush or you can't get it to clear the ERA's chassis X-brace. I can post pics if somebody actually gives a shi*.
Old 07-07-2022, 09:38 PM
Thanks for the bolt in confirmation guys!
Patrick, I would like to see the TKO boss mod. The TKX casing is smaller but it may have the same fitment issue with X brace
Old 07-08-2022, 05:37 AM
This is the TKO boss that requires grinding:
Old 07-08-2022, 09:42 AM
Here's a pic of a TKX from Summit. It looks like it has the same boss.
Old 07-08-2022, 10:36 AM
And here's a pic of mine installed. Remember the engine goes in first, then the transmission well behind the engine, then you push it forward to mate. Like everything else on the car, whether it's dropping a transmission, putting in a new relay, or taping up a loose wire, you've got about a quarter inch of clearance to work with.
Old 07-08-2022, 10:38 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
I have a TKX in my garage waiting for 838 to show up. It looks like a direct bolt in for a TKO except it looks like no boss to remove.
Old 07-08-2022, 10:42 AM
Did it look like there ever was a boss? Or did someone just politely remove it for you.
Old 07-08-2022, 01:53 PM
Grubby's Avatar
Patrick,
The rear of the TKX has a much different shape. Actually the entire trans is smaller and more stream lined.
Old 07-08-2022, 02:02 PM
Patrick,
Hmmm, does your TKX look like the picture I posted above of the TKX from Summit?
Old 07-08-2022, 03:39 PM
Grubby's Avatar
The picture looks like mine.
Old 07-08-2022, 03:42 PM
But you don't have that big-ass boss sticking out the side like a pack of Juicy Fruit?
Old 07-09-2022, 05:38 AM
mrmustang's Avatar
I can confirm that the old style boss is not on the new style transmission.
Bill S.
Old 07-09-2022, 07:03 AM
Well alright, that answers that. Thanks, Bill.
Old 07-09-2022, 08:24 AM
The major issue i had putting the TKX transmission in . Was the spacer alignment. The holes wasn't centered. With the spacer, it pushed the transmission back. On the earlier models Era the emergency brake mount is not removeable so trying to get it aligned and pushed in was a big issue for me.
Old 09-07-2022, 04:43 PM
Registered User
Cobra Make, Engine: ERA FIA 2163, 331 CI
I have ERA 2163 (sort of; it's at the painters), so yours is sequential to mine. From what I researched, the TKX is a better fit, and also has a higher RPM limit (7,000+ vs. 6,200 for the TKO). I decided on a toploader, due to building a high RPM 331; from what I recall, the RPM difference in fifth would only save around 500 RPMs at 70 mph.
