Like Tree5Likes
  • 3 Post By g4g2g7
  • 2 Post By strictlypersonl
Old 07-09-2022, 09:21 AM
RockBit's Avatar
Default Expansion Tank Cracking
I have had my expansion/surge tank crack twice, and have had it repaired at a radiator shop both times. I can't remember the particulars about the first time (cracked in solder joint between tank bottom and tube to thermostat), but the second time it cracked was after a hard acceleration. It cracked in the corner of the tank top on the passenger side.
After searching, the most likely explanation is that the upper radiator hose is too stiff, and stresses the surge tank when the engine rocks over from torque.
Short of buying a new, stronger surge tank, does anyone have a suggestion for how to fix this?
Chris
Old 07-09-2022, 09:57 AM
Cobra Make, Engine: Hurricane HM1021, 390FE TKO600
Might just be the angle of the photo, but looking at something simple first that might tie into your comment about stress under torque, kinda looks like the upper hard elbow doesn’t line up with the radiator inlet preloading the setup?
jolsen42, DanEC and Kthulu like this.
Old 07-09-2022, 09:59 AM
Yes......go to a SS tank and change the hoses to silicone rubber hoses.....
Check out Pegasus Racing or HRP Racing....
Morris
Old 07-10-2022, 09:30 AM
bobcowan's Avatar
If the engine is moving enough to damage the tank, it's putting stress on other areas as well. You've only discovered the weakest link. When you fix that, you'll find the next one.
I would install solid motor mounts. Cheaper. Easier. Fixes everything
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 07-11-2022, 06:37 AM
RockBit's Avatar
I think what you are seeing is just from the angle of the photo. The hose connecting the upper radiator outlet to the tube has a radius in it and is short.
Chris
Old 07-11-2022, 06:38 AM
RockBit's Avatar
Thanks for the suggestion. I am hoping to fix this without having to purchase a new surge tank. They seem to be in short supply, as well.
Chris
Old 07-11-2022, 06:41 AM
RockBit's Avatar
I have an aluminum block. With solid motor mounts, would the be a danger of stripping the motor mount threads in the block? My engine dynoed at 660 lb-ft…
Chris
Old 07-11-2022, 07:29 AM
This might help.
https://erareplicas.com/427man/engin...tmod/index.htm
Old 07-11-2022, 08:40 AM
RockBit's Avatar
Originally Posted by strictlypersonl View Post
Thanks Bob, but I already have the bolt through the motor mount.
Chris
Old 07-11-2022, 09:59 AM
bobcowan's Avatar
Not a problem. I also have an alum block, and am making similar power.
.boB "Iron Man"
Old 07-12-2022, 12:19 PM
Chicagowil's Avatar
And solid motor mounts on race (1/4 mi) cars are prone to causing cracks in the side of the block around the mount bolts.
I would suggest replacing the alum elbow and rubber couplers with a pre-formed rubber hose. It would allow for more twist and flex as the motor moves around.
Old 07-12-2022, 01:43 PM
RockBit's Avatar
Great suggestion and something I am thinking about. First, though, I am going to rig something up to help me measure the movement of the engine to make sure of the cause. Stay tuned and I’ll post the results.
Chris
Old 07-16-2022, 09:12 AM
RockBit's Avatar
I measured the engine movement during a spirited drive and got 1/4 inch. That makes sense as I have a bolt through the engine mount on the driver side.
It does not, however, explain the surge tank cracking. I’m stumped now, and I guess I won’t worry about it until it happens again.
Thanks to everyone for their comments and suggestions.
Chris
Old 07-16-2022, 11:49 AM
sunman's Avatar
Maybe the weight of your elbow flopping around and the lack of flexibility is causing the metal fatigue problem.
Make a one piece rubber elbow fit and replace the four ugly hose clamps with two Earls AN style hose fittings to match those other two.
Chaney Shores Studio
Old 07-16-2022, 02:26 PM
How about something like this?
https://www.gates.com/us/en/fluid-po...00-000000.html
Morris and Sargie like this.
