Old 11-28-2022, 10:11 AM
Cobra Make, Engine: ERA #492, 468ci Pond Aluminum Side Oiler
Default TKX transmission
I want to put the TKX in ERA 492 and there appear to be several options. Should I spend $1,000 on a new Quicktime bell housing or get one of the kits that comes with an adapter plate for my Lakewood bellhousing. My main concerns are to get the stick in the right place and the transmission mounts to line up properly. Also, which clutch do you recommend and should I consider switching to a hydraulic TO bearing setup?
Thanks!
Old 11-28-2022, 11:09 AM
When I changed out my 4 speeds to tkx transmission. The location wasn't the problem. The emergency brake assembly was in the way, when you are trying to put the transmission into pilot bearing. That was my biggest challenge.
Old 11-28-2022, 03:27 PM
DanEC's Avatar
I didn’t realize QuickTime Bell housings are that expensive now - but I used the non-SFI rated one that provides more ground clearance in my car. The McLeod RST twin disc clutches are really nice and light pressure but expensive. If you go to a hydraulic throw out bearing it’s a good idea to rig up a clutch pedal stop to prevent over-extending the TO bearing and failing it.
ERA 782 Running
Old 11-28-2022, 03:43 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
A TKX is a direct replacement for a TKO.
Get the same input shaft length and OD and you will be happy.
Use your current bell.
Old 11-28-2022, 05:04 PM
They did not offer a short shaft. When i bought my transmission
Old 11-28-2022, 07:13 PM
jknich's Avatar
Modern Driveline has a special version of the TKX for a Cobra. Small and big block versions. Bolt right up to replace a T5.
https://www.moderndriveline.com/shop...sion-packages/
Jim Nichols
