November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Like Tree8Likes
  • 1 Post By twobjshelbys
  • 1 Post By eschaider
  • 1 Post By strictlypersonl
  • 2 Post By Grubby
  • 1 Post By KarlzEE Bebout
  • 2 Post By Grubby
Old 10-29-2024, 02:41 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Default Dash area squeak at idle - both sides
838 has a squeak that mostly is audible at idle. It seems to be in the dash area on both ends. On bumpy roads or sometimes body twisting, it can be heard.
I initially thought steering column. I put some anti-squeak tape between the steering column and the mounting bracket. That is not it.
I can't seem to isolate it. I have pulled on various parts and no luck.
Anyone seen anything common to the ERA Cobras on a likely area?
John
Old 10-29-2024, 04:20 PM
Alfa02's Avatar
Gold Star Contributor
(Karlos) Karl Bebout, you out there Brother? If anybody would have had an issue with their ERA, Karl has seen it, he has close to 100k miles on his
Grubby, I have Karlos phone# if you need to reach him, he usually cut's me off at an hour, he done talking to me Scratch that "Listening to me"
Cheers Tom.
Cobra Make, Engine: shellvalley 428 ford
Try snugging down the bolts that hold it in also the dash support bracket
Old 10-29-2024, 04:43 PM
twobjshelbys's Avatar
If this was an original the answer would be:
Ken Miles: It rattles and squeaks at idle.
Shelby: You're paid to drive it at 200MPH. If you can hear it squeak then let me know.
It's a race car. Mine was full of rattles and squeaks. It meant it was alive.
spl310 likes this.
Tony
CSX4005LA
Old 10-29-2024, 05:56 PM
eschaider's Avatar
John,
Your exhaust is obviously not loud enough. This sort of audible aberration should be undetectable anytime the engine is running.
spl310 likes this.
Old 10-29-2024, 06:48 PM
It's probably just mice.
Old 10-30-2024, 03:22 AM
Exclamation Nope!...
... it's the squirrels under the hood!
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
Old 10-30-2024, 06:43 AM
Make sure that it's not an exhaust leak at the head. Sometimes they squeak.
twobjshelbys likes this.
Old 10-30-2024, 06:46 AM
DanEC's Avatar
I know you have built a couple ERAs so it’s obviously not something simple.
Seeing as it’s on both sides, windshield frame mounts rubbing on edge of body cuts? Were the foot boxes fully bonded in?
Kind of odd as although I’ve got a little hearing loss mine seems tight as an anvil with the exception of a slight tinny sound underneath that must be something in my exhaust or the baffle in the fuel tank which clanks around as I don’t keep much gas in the tank. I guess you’ve asking ERA for any similar experiences they have dealt with?
ERA 782 Running
Old 10-30-2024, 05:18 PM
Grubby's Avatar
Thanks for the comments.
I don’t think it is the windshield - I have held it during the noise to no effect.
Exhaust is possible - I will check that.
I will find it. It may take time; I am relentless on things like this.
John
eschaider and Alfa02 like this.
Old 11-02-2024, 10:36 AM
Grubby, sounds like you've looked at all the usual suspects. Maybe, if you are very unlucky, the squeeeeeek is coming from the bell housing area. Perhaps the block plate? Just for grins, check all the bell housing bolts. You might get lucky. My 2¢
Alfa02 likes this.
Old 11-02-2024, 08:21 PM
Cobra Make, Engine: Superformance 351w tremec 5spd
I had a squeak that I couldn’t find under my dash. While opening my hood latches I heard a similar type squeak. I put some grease on both latches and catches as well as the rubber stop. To my surprise the squeak went away.
Old 11-03-2024, 10:15 AM
Grubby's Avatar
FOUND
Throttle linkage with the main squeak from the heim joint that is mounted directly behind the carb. As the engine moved back and forth, the throttle shaft slips thru the heim joint. A dab of grease and the problem is solved.
I greased the throttle pedal shaft as well, but I don’t think it was contributing.
This shows sounds travel and are very hard to determine the origin.
John
twobjshelbys and Alfa02 like this.
Old 11-03-2024, 01:55 PM
Good work
Tony
CSX4005LA
