Old 05-13-2002, 05:37 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Again, sidepipes are not inherently deafening. There are some undercar systems that are louder. Use a large glasspack, and you can have good sound control as well as good flow.
It likely varies from make to make, but there isn't much room for an undercar muffler.
That being said, some years back, Walker made chambered pipe exhausts, and may still today. Something like that would work.
Old 05-19-2002, 08:18 AM
Turk's Avatar
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
If you drive faster than the sound of the side pipes, the noise and gas fumes are left behind. I smelled nothing I heard nothing. After a 1500 mile trip, the noise was NOT even an issue.
Currently in the process of modyfing the exhaust system so it WILL become an issue.
TURK
OBAMA IN in 2012
Old 05-19-2002, 08:51 AM
Ron61's Avatar
Default re sidepipes
Fred,
Since the collectors bolt right onto the headers and nearly all of the Cobra headers I have seen come straight out toward the cutout in the side of the car for the collectors to come through, adding under car pipes to this setup would be difficult to say the least. If you can find some short headers that turn back toward going under the car you maight make it work but it will take some doing.
Ron61
Old 05-19-2002, 10:41 AM
Dwight's Avatar
Default CHAPLIN
CHAPLIN,
LOOK IN THE APRIL 30, 2002 SUMMIT CATALOGUE ON PAGE190. THEY SELL INSERTS FOR HEADER COLLECTORS LIKE THE ONES WE USE ON COBRAS. THESE ARE MADE BY CAR CHEMISTRY, INC. THERE ARE OTHERS SOLD BY DIFFERENT COMPANIES. AND YOU COULD MAKE YOUR OWN.
JEGS PAGE 15-K
Old 04-05-2003, 12:13 PM
Cobra Make, Engine: ERA, Ford 428 SCJ
Here's ERA 003 with undercar exhaust. I redid the entiresystem from headers to tips. I also went without mufflers so it's plenty loud.
However, it's not loud enough.
I'm going to install sidepipes soon, no mufflers in them either.........
(I want my neighbors to REALLY hate me!)
Old 04-05-2003, 12:44 PM
BTW,
Anyone interested in a complete undercar exhaust system for an ERA let me know.
Sanderson headers, Jet-Hot coated with aluminized pipe and crome tips, ready to bolt right up.
Old 04-06-2003, 05:29 AM
I have a car with undercar exhaust that exists in front of the rear wheels. I think this is the best of both worlds as you get (1) 'big' sound, but not at all punishing to you and your neighbors, (2) the aesthetics are very pleasing as they show off the car's shape better...nothing gets in the way of the lines of the car, (3) you don't burn any part of your leg exiting or entering the car (this is an important safety issue if you have kids anywhere near the car), and (4) for resale, it actually gives the buyer the option to keep the undercar exhaust...no holes are put in the body of the car.
Tha's my 2 cents.
Old 04-06-2003, 07:54 AM
JWheaton's Avatar
Cobra Make, Engine: ERA 389 427s/o
ERA620
Did ERA install that exhaust system or is it your own design.
Would you be able to post some pictures?
Thanks
Jamie
Old 04-06-2003, 08:48 AM
Default Attn: Jwheaton
Jamie:
We need to talk. I live in Milford and am looking to build the same car. I have done a bunch of research, have pic's of original 427 (428) cars, etc. I am starting to build the engine and will probably be ordering my car in a year or so from ERA.
I can be reached @ fzabski@technologyrevealed.biz if interested in talking.
Old 04-07-2003, 03:27 PM
I just might have found the only downside to undercar exhaust: I can hear the 'normal' buzzing of my ignition controler under the dash when I am at a stop light. Not a serious problem, but it is annoying.
era620
Old 04-07-2003, 05:47 PM
Club Cobra Member
Original Shelby Owner
Cobra Make, Engine: Purchased CSX3225 in 1968 for $4,995. Original 428 car but changed to 427 MR about 20 years ago.
My car came with undercar exhaust. Me and my wife went on a picknick in the car and I took along a gun with several hundred rounds of ammo. I was going to do some target practice out in the Dessert near Palm Springs. About half way there my wife smelled something burning. I thought it was just some of the Chemical plants along the way. A few miles later I decided I better take a look in the trunk since the smell was getting pretty strong. My thought was what could be burning in the trunk. Well when I opened the trunk I noticed the blanket we had brought along with the ammo sitting on top of it was smoldering. I yanked out the paper bag with the ammo and then pulled out the blanket and it burst into flames. What happened is that the undercar exhaust had shifted and burned through the fiberglass cover in the trunk. The original cars have a couple of fiberglass covers that make room for the undercar exhaust. So if you go with the under car exhaust just make sure it stays where it is supposed to be.
I put some aluminum and insulation behind the hole burned into the fiberglass and not long after that I went to the side exhaust. I found the side exhaust definately improved performance from my PI 428 that was originally in the car. Although it is noisier I find the buffeting of the wind and the heat to be more of a factor on long drives than the noise. I also find it tougher to take the car for long drives now that I am 30 years older.
Have fun, Ray
Old 04-09-2003, 04:39 AM
Fortunately, the ERA design keeps the exhaust well away from the 'glass.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Display Modes
