Old 08-18-2002, 04:18 AM
Default Front Wheels
Hi Bob, met you at the shop last monday. Hope your wiring guy is back to work, you were lookin' a mite frazzled! Anyway a quick question, would 11' wheels fit up front on the 427 w/o modification? I like the deeper dish look of the rears. I will have 6 pin drive 17'' wheels. Just wondering!
Regards
I'm Back! After all this TIME!!!
Old 08-18-2002, 06:22 AM
Hotfingrs's Avatar
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Keep in mind that if you're going to try and put deep dish wheels on the front, they will stick out 3 1/2 to 4 inches farther than the present front wheels...also if you don't have 11's on there now, you'll have to add the additional inches to the stick out. Also if you try to put 11 inches under the body, more than likely you'll hit the frame with the tire while turning....
Jack
XSSIVE .....
Old 08-18-2002, 08:04 AM
Fingrs is correct. While we can fit 9.5" wide wheels in the front, most of the change in offset is toward the inside.
The correct offsets are posted here.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 08-18-2002, 08:38 AM
Thanks to both of you. One less thing for me to think about in this process!
Old 08-22-2002, 05:04 PM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Baxter:
Do not try to reinvent... Bob has been there... Stick with what he recommends
Morty MacTavish
