Old 10-20-2002, 05:49 PM
SSSnake's Avatar
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Send a message via AIM to SSSnake
Default Got the fuel pump mounted
This took two nights to put together. Holley blue pump and a fram hpg1 fuel filter. It is 3/8 aluminum bolted into nut-serts in the frame. The pump is wired into the harness and all of the hoses are connected. The only problem now is the battery box cover on the other side can't even compare to this piece
Glenn
Old 10-20-2002, 05:58 PM
SSSnake's Avatar
Old 10-20-2002, 06:00 PM
SSSnake's Avatar
Old 10-21-2002, 04:34 AM
If you have a little room, I recommend using rubber isolators for the pump. It'll keep the noise down. Available from
McMaster Carr
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
Old 10-21-2002, 12:47 PM
chopper's Avatar
Cobra Make, Engine: Previous ERA owner on break
Default Regulators
SSSnake:
Just a random thought here. You didn't say what fuel metering system you plan to use when you get the engine installed (carb or EFI). I can't tell from your photo, but it doesn't look like you have a pressure regulator hooked up to this system (unless, of course, you are planning to add that up front). However, the Holley BLUE pump (according to their website):
http://www.holley.com/HiOctn/ProdLin.../12-802-1.html
is factory set to 14 psi output. Their graph shows relatively stable pressure output of 12 - 14 psi up to 80 gph. This pressure is more than the needle valves in most carbs can handle, so a pressure regulator is usually required for carbed engines when running the BLUE pump. Their RED pump (the one I use) is set up to about 7 psi; I've measured mine at about 6 psi at idle and decreases to about 4.5 at cruise. It's my understanding that if you run much more than about six psi, you can overpower the needle valves and flood the carbs. Just something to consider. If I missed the regulator installation in your photo, kidly disregard all after "Hello" and I'll fade quietly.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
Old 10-21-2002, 01:03 PM
SSSnake's Avatar
Chopper,
We are using a Holley 4150 650cfm. It was recommended to mount the regulator as close to the carb as possible, so it is going in the engine compartment.
Glenn
Old 10-21-2002, 02:12 PM
Tom Wells's Avatar
Hi Bob,
That was a little tiny scavenger hunt
Here's what McMaster calls'em: "Rubber Sandwich Mounts"
Took a little hunting, but hey, that's the fun of it!
Thanks for the tip!
Tom
