Old 10-12-2003, 02:30 PM
Cobra Make, Engine: ERA #652, street version, 428.
Default turn signals
Hi Bob, Allen Johnson here, ERA#652. I'm not using the ERA or Triumph steering column but would like to wire up a toggle switch for the turn signals. I see the old wiring diagram you showed here that you said used to be in the manual. Questions: 1) is that the appropriate diagram for what I want to do, and 2) I don't understand what it means to use B/W/G between the FLASHER and the COLUMN SIGNAL SWITCH. Black, white, green of course, but not put together obviously???? Hopefully these are my last questions on the car - it's otherwise done!!! Drives great and looks great! Thanks a lot.
