Old 12-26-2003, 08:25 AM
Banned
Cobra Make, Engine: ERA 428 FE 4-speed CR "TL" heavy spline
Default Side Pipe Dent/Interior Door Hardware
I've ended up with a small dent in one of my side pipes. Is there an easy fix for this?
Also, both doors latches probably looked good when the ERA was built in the 1980's, but the chrome has gone south, so are those latches replaceable or is re-chroming the way to go?
Any input would be appreciated.
Old 12-29-2003, 03:39 PM
Cobra Make, Engine: ERA / nascar side oiler
The " Finish Line" sells door latches .
With side pipe off , if you can get to the dent with tools and get it
red hot with a tortch , you might be able to spoon out your dent .
Old 12-30-2003, 09:47 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Cobra:
Another alternative with respect to the sidepipe (if they aren't stainless) is to have a bodyshop use a "puller" with a temp. welded on rod. (Do I quite know what I'm talking about? Naw, but I would ask them if it were possible.) Of course the sidepipe would then have to be refinished...
