Old 03-09-2004, 09:02 PM
Cobra Make, Engine: ERA 675 - 427 SO
Default Installing a 427 with trans attached?
Can anybody tell me if it's possible to install a 427 with a Richmond 5 speed already attached. Thanks, Tom.
Old 03-10-2004, 03:53 AM
It's not worth the aggravation. Assemble on the floor first to check fit, then remove the trans from the bell housing for installation.
Old 03-10-2004, 05:54 AM
cobra's Avatar
Cobra Make, Engine: ERA 427 SC # 571, 472 Shelby aluminum "stroker " CSX # 299 from Gessford, 48 IDA Weber carburetors from Jim Inglese
Smile
Tom,
I installed as first the engine with the bell housing and then from inside the Richmond 5 speed.
It's a nice work.
Good luck
Walter
Greetings from Switzerland
Walter
http://www.kreuchi-auto.ch
Old 03-10-2004, 08:34 AM
Clois Harlan's Avatar
Tom,
I know I don't have a 427 SO but I have installed my engine and trans together several times (unfortunately) pretty easy if you have one of those engine pitch attachments to your cherry picker. Just have your front end raised at least a foot off the ground so you can work into your angle. I know Jay has done at least one this way.
Clois
"Let's roll"
"Be part of Something Good
Old 03-10-2004, 06:54 PM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
Do it the way Bob (Mr. Strict.... ) sez.
Don't try any short cuts or
(after 660 plus cars) figure you can ignore his advice.
He knows best (as I can sure attest)
PS: and now Bob, have you figured out my small block motor mount bolt thingamabob yet?
Old 03-10-2004, 07:40 PM
Default engine and trans
We installed a 427" center oiler AND clutch with Lakewood bell housing assembly into my friend Robert H's ERA 427 # 6~~? several months ago.
Trial fit the Tremec TKO first to the housing...had the clutch, flywheel, etc. all on and ready.
The KEY!!!!! to a SMOOTH, EASY install was a CHAIN DEAD-FALL...NOT a cherry picker/shop crane.
The chain dead-fall lets you drop the lump straight down, not in an ever changing ARC like you get with a cherry-picker/shop crane. You can adjust the angle with the plate bolted to the intake manifold.
Robert's garage has an overhead beam that let us hang the deadfall...(not everyone has that luxury...sniff, sob!).
We used my shop crane to install the engine and bell-housing in my 289 FIA car last year, and it was a PAIN with the shop crane...going in from the front of the car, padding the nose of the car, trying to move the crane/car to accomadate the swing of the cranes arm, on an asphalt driveway...!
(that said, I can not say for sure going straight down would work in a FIA 289 car to clear the front x-member...also, the 289/302 block I have is a LOWER HEIGHT assembly engine compared to a 351 block to clear at the fire wall...something else to think about... if you have a 351 block to go into the small block FIA car!)
But, in my humble opinion...THERE IS NO WAY to get the engine, bellhousing AND TRANS in the ERA 289FIA OR the ERA 427".
If you are doing an install, we used THREE people with both cars...on the FIA 289...one to work the lift, one on the sides to slip the headers up and around the engine as it settled in, and one sitting in the car on the chassis "X"...pulling the engine/bellhousing to come up and back into position...almost the same thing with the 427", but with the dead fall chain, no drama, no engine swinging back and forth, just very relaxed.
As I understand it a real AC Cobra/ACE has a removable center chassis section, so the whole engine/bellhousing/trans goes in no
problem, but not these cars I doubt it...absolutely WORTH IT for a torsionally stronger chassis.
Get three savy helpers, put on the clutch and bellhousing...LEAVE OFF THE TRANS. If you can use the dead-fall chain, man it makes things easier...!
Clois, greetings...does your car have a removable center section?...I can not visualize how you could do the job on either of the ERA cars, 289 or 427.
I have pulled and re-intalled the 327" engine/trans by myself with a cherry-picker in my 67' Corvette no problem...but there is no shortage of clearance under the car to drop the assembly down and swing it UP for trans.
Pete
ERA 289 #2027
Old 03-11-2004, 08:57 AM
No problem, did it twice last year with my wife as a helper.
I pulled the front wheels off so I could push the cherry picker in from the sides at an angle and I placed blankets and a fender cover on my fenders. I worked the cherry picker while my wife kept the engine from swinging and adjusted the tilt. I used the Goodwrench cherry picker that is sold at O'Reileys for about $200. Once the trans is under the firewall everything goes pretty smooth. I did pull my headers off, as well as my alternator and water pump for the install. The whole thing takes about 2 hours max.
I have also pulled my engine leaving the trans and bell housing in place and unbolting the starter and bellhousing then fitting the engine back to the bellhousing. This was actually easier than I had suspected. I didn't want to mess with my hyd tob in addition to re-installing my engine. I may have just got lucky a few times but it really was quite simple.
Clois
"Let's roll"
