November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 07-12-2004, 08:42 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Joe, I never use a spray on the header gaskets to the heads, but if you have iregularities in the surfaces at the side pipes, you might want to put just a little on to help keep the gases out of the engine bay.
The white gasket board from Mr. Gasket make great side pipe gaskets. It is what I use.
Just a quick note, you might want to gasket the flang to frame mounting as it will reduce the amount of noise in the cockpit.
