November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 11-26-2004, 07:11 AM
chuckbrandt's Avatar
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default ERA - What do we use to glue down carpet?
What do you guys use to glue down the carpet? The instructions are kinda vague. I'd like something in an aerosol spray can or I guess brush on if possible.
Thanks, Chuck
Build website at www.chuckbrandt.com
Old 11-26-2004, 07:36 AM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Use DAP Weldwood adhesive. Make sure you use the Gel formula, it works much better than the liquid Weldwood adhesive.
Replica is not a dirty word.
Old 11-26-2004, 08:55 AM
joea's Avatar
Cobra Make, Engine: ERA #676, 428SCJ (2x4), TKOII
Chappie is right...plain old contact cement. Brush it on both surfaces (back of carpet and interior body panel) . Let it dry until it is no longer tacky to the touch (usually 15 minutes or so). Then apply the carpet to the interior. A trick I used for larger pieces was to put wax paper on the areas, then peel off the wax paper and stick the carpet as I go. Also make sure you have several new utility knife blades for trimming the pieces
"There are 10 types of people out there....the ones that understand binary and the zeros that don't."
Old 11-26-2004, 10:25 AM
I had to strip the interior of carpet and re-install. I used a spray on "contact" glue and it didn't hold very well at all.
So I pulled it all out and next used some spray on "commercial heavy duty" really sticky glue.
... it didn't hold either. Looks like a brush and DAP is up next!
In both above cases at first it looked like it was working well. A few weeks and ENGINE HEAT and the carpet was sagging badly on the sides and under the dash area. The "floor" was fine, after all it hasn't got anywhere to "fall".
Old 11-26-2004, 11:53 AM
Junket's Avatar
Cobra Make, Engine: shell valley
When I put mine in started with contact cement wasn't proficient enough to get it in the right place the first time even with wax paper so went with premium grade liquid nails and my glue gun that worked for me. I did install insulation first.
Ken
Talent is your head in communication with your balls.
Old 11-26-2004, 01:43 PM
SSSnake's Avatar
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Send a message via AIM to SSSnake
We used the 3M spray on Super Adhesive. After two years, not one piece has moved.
Glenn
Old 11-26-2004, 05:03 PM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
I used the 3M spray on adhesive as well. It's way easier than using a brush to apply contact cement. If I remember correctly, you'll need about 6 cans.
Chris
Old 11-26-2004, 05:16 PM
Steve Kirkham's Avatar
Cobra Make, Engine: Kirkham KMP 666
Weldwood Contact Cement
_____________________
All submitted text is my own opinion, not that of Kirkham Motorsports.
Steve Kirkham, Manager
Old 11-26-2004, 05:26 PM
Chaplin's Avatar
Yup, that's the stuff.
Old 11-26-2004, 06:11 PM
joea's Avatar
I din't use the gel...looks like it would have been a bit easier
Old 11-26-2004, 08:08 PM
Turk's Avatar
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
Since it is contact cement and requires application on both surfaces, it needs to be allowed to dry to tacky before joining the two surfaces together.
When one surface is pourous like carpet or insulation is, apply it to that surface first. Let it dry. That seaals the pourous surface so it won't keep on absorbing the glue.
Then apply glue to both surfaces, let it dry to tacky. Join them.. It ain't going nowhere!
TURK
OBAMA IN in 2012
Old 11-28-2004, 06:30 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Chuck:
When using contact cement you've only got one chance to get it right. Once those surfaces contact one another that's it so make sure you've positioned (dry fit) everything first.
DonC
Old 11-28-2004, 08:33 AM
ERA 626's Avatar
Cobra Make, Engine: CSX 6079 482CI CSX cross ram
The 3M spray worked great for me. buy about 6 or 8 cans.
Old 11-29-2004, 08:48 AM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
ERA uses a commercial grade contact cement. You only get one chance with it, but it doesn't come undone after a few weeks or months.
Take your time... don't rush the job. Don't start in after a stressful day at work... be calm.
The most difficult job is the top of the passenger side foot box.
J
Old 11-29-2004, 08:58 AM
Ibr8k4vetts's Avatar
Your Cobra must be huge, It only took me 2.5 cans and that was with the trunk and heat blanket.
Mike
