January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 11-30-2004, 09:46 PM
Melzer's Avatar
Cobra Make, Engine: ERA Cobra 427 so, Holman Moody dual 4v
Default ERA 297 hood cutout
After getting tired of the small and incorrect K&N air cleaners on the car when I purchased it, I decided to do the right thing with the 2x4 Holley setup and top off my side oiler with a pair of Stelling/Hellings as I did with my other car with a single Holley.
After admiring those shiny discs and blue decals for awhile, I decided to close the hood. I then realized that the hood cutout was way too small to accomodate the 8-1/2" diameter air cleaners.
The finish opening width was only 7-1/2" (inside/inside of edge trim) the car was supposedly setup for "cut hole in hood & setup for dual quads & rivets" back when the car was done by ERA.
What I can't understand is how would the "dual quads" hood cutout be setup with an air cleaner cutout width smaller than the 8-1/2" that were period correct?
Any suggestions would be appreciated. I should note that the intake is an original Holman Moody with 4224 Holleys. The underside of the hood is lined with aluminum
As always, thank you for your expertise,
Mel
Melzer....
"if they drove 427 Cobras in hell....everyone would be dying to get in."
Old 11-30-2004, 10:07 PM
Hmmmm,,,, gotta be pretty straight forward, you need a slightly bigger hole.
Not being funny (all though I am, )
I'm running 2X4 Holleys with the Stellings and they fit "tight", but they clear. Mine is a high riser intake, the carbs stick through the hood and up into the air scoop, where the "just" clear there as well.
...alloy lined hood? Nice!
