Old 12-03-2004, 10:24 AM
Fox's Avatar
Fox Fox is offline
Cobra Make, Engine: 302 done, CSX289 comp body, leaf spring chassis to original specs...
Default Trigos??
Will the Trigo FIA styles wheels fit an ERA.
They list the wheels as 7 1/2" X 15" front and the rears as 9 1/2" X 15", both with 3 1/2" backspacing. I am concerned of the backspacing and the wheel well room.
In looking at my ERA manual it lists Team III and PSE but not Trigo. Has anyone used them? Happy???
Thanks,
-John
So you been broken and you been hurt, Show me somebody who ain't
Yeah I know I ain't nobody's bargain, But hell a little touchup, and some paint...
Old 12-03-2004, 01:28 PM
Hey Fox.....did you ever get that old small block of yours running?
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 12-03-2004, 02:50 PM
Fox's Avatar
Fox Fox is offline
Blykins,
Why yes I did. Plug to the lifter valley, oil problem solved...sorted out a small fuel and electrical problem with my homemade test stand and then VVVVRRRROOOOMMMM... Some stand pics in my gallery.
I plan to get some bugs out...tinker with the carb and the timing and learn a little more...
I have redone two bathrooms and have a little basement work to do...we have a 2nd baby due in February and that is kinda the deal I've made...Need to take care of the WE, before I can move on to the ME... if you know what I mean.
If all goes well, a deposit on an FIA goes in after the first of the year.
Thanks for asking.
-John
Old 12-03-2004, 03:33 PM
AFAIK, nobody's used Trigo's FIA wheels. Too new. I'll send Lyn our offset specs on Monday to confirm compatibility.
Old 12-03-2004, 06:29 PM
Fox's Avatar
Fox Fox is offline
Thanks Bob, I appreciate your looking into it.
AFAIK??
-John
Old 12-03-2004, 06:53 PM
As Far As I Know -
Old 12-03-2004, 07:04 PM
Fox's Avatar
Fox Fox is offline
...DOH....
Old 12-08-2004, 04:54 AM
Coincidentally, we just got a set of Trigos. The fronts will require some backspace increase (which will be relayed to Lyn Park), but there's lots of material to do the machining.
Old 12-08-2004, 05:13 AM
Fox's Avatar
Fox Fox is offline
Thanks Bob for looking into that. I will ask Lyn about making the backspacing adjustment.
Just how much of an increase is needed for the front wheels?
-John
Old 12-08-2004, 06:39 AM
We machine about 0.4" from his standard setup, increasing the backspacing and narrowing the hub depth. Apparently we've already done a set like this but I was not privy to the process...
Old 12-08-2004, 07:29 AM
Fox's Avatar
Fox Fox is offline
Bob,
I look forward to solving such a high class problem. I am sure our paths and this issue will cross again soon.
Until then...
-John
