Old 05-01-2005, 06:37 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Email bob and he can send you a link to the full owner's manual with all the photos and drawings. Restricted to registered owners.
DonC
Old 05-01-2005, 03:28 PM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
Thanks everyone,
I know you all are trying to help & I really appreciate it, But it would appear that you all are using B/B W/ TKO's.
Mine is a 408W--W/TL as per original post
& that seems to be where the problem is.
Sorry for all the trouble but I really need to get this solved as my builder doesn't seem to be able to get a handle on this problem.
Many thanks again
Craig
Old 05-01-2005, 06:39 PM
cdnus,
You've hopefully gotten the link to the full manual that I sent you.
This setup should be very straightforward, using a clutch fork and a slave cylinder that mounts to the flange of the blow shield. If they don't have the correct bracket for the slave, give me a call so that we can send them one.
Definitely not rocket science.
Old 05-02-2005, 05:47 PM
Thanks Bob,
I ordered a complete bracket, slave & rod assembly from Pete on Fri. Hopefully UPS will have it to him by WEd. or Thurs.
I am gratefull for all your time & trouble.
Thanks again
Craig
Display Modes
