Old 08-04-2005, 07:01 PM
P Martin's Avatar
Cobra Make, Engine: ERA 427SC #621 silver/black stripes /427 center oiler
Default Brake Lights
Bob
You recently sent me a new brake light swich. I am noticing that the brake lights come on only when I press hard on the brake pedal. I see this on other ERA's also. Any fix for this?
Pat
Old 08-05-2005, 03:59 AM
There must be some variation on the trigger value of the new switch. The lights on the cars in the shop come on at about 2 lbs pressure to the pedal. I will send you another switch.
Old 08-05-2005, 04:12 AM
Bob,
Last year I too recieved a new switch and I also have a light problem. I passed inspection but the problem still have the problem with the lights. I also have 2 split primary exhust tubes and 1 broken weld on the my headers. The 2 split are #3 down the center and #6 just past the flange weld. #4 is broken loose just above the colector all the way around the tube.
I was wondering about this and if the headers and exhaust pipe are only supported at the engine and the rear mounting bolt if the stress of hanging bracket and the flex of the engine may effect the exhaust header? Any help or insight with the lights and replacing the headers would greatly appriciated.
Thanks,
Corky
Old 08-05-2005, 03:04 PM
P Martin's Avatar
Bob,
Thanks alot. I know I made a good decision buying an ERA. You run a very reputible company.
Pat
