Old 07-13-2006, 06:47 AM
DrC DrC is offline
Cobra Make, Engine: ERA 711 390 FE w/ TKO 600
Default adding a cigarette lighter
I want to know two things please. One how easy is it to install a lighter. Secondly I want it for a instrument to measure performance (horsepower, torque 1/8 mile and 1/4 mile times). What is your thoughts on these types of products? If they don't work I can always use the lighter for my radar detector.
Old 07-13-2006, 06:50 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
As far as the Assesory Power Outlet is concerned, you may want to try to get a unit from the back of an Chevy SSR. They are well made and have a seal on them. Your local GM dealer can order one for you.
It is what I use and I run a GPS from it.
It also will allow a lighter to be pushed in.
Hope this helps.
Old 07-13-2006, 07:02 AM
DrC DrC is offline
Would I connect it to the wire harness where it is slated for a lighter?
Rich
Old 07-13-2006, 07:55 AM
trularin's Avatar
Member of the north
You may want to put an "inline" fuse for the red wire @ 20 Amps.
I wired it to the battery so I could run air pumps and lights at night for repairs.
Old 07-13-2006, 08:03 AM
Yetiman's Avatar
Cobra Make, Engine: Arntz/SBC/Jag
I added one in my Arntz to run the G-tech pro. I bought one from an auto parts store for $9 that had ears on it to mount on a flat surface. I mounted it to the top of the passenger side foot box a ways back so it was out of sight. I added a fuse holder inline, and went to a power block I had on the top side of the footbox (which I put in myself when I added the MSD type box).
Not too hard to do. The Gtech pro works great and seems to be quite accurate.
We come into this world naked, screaming, and covered in blood. With dedication and a little planning, you can go out the same way.
View my overflow Gallery (much more to come !)
Old 07-13-2006, 08:42 AM
DrC DrC is offline
thanks guys,
Trularin explain to me what an "inline " fuse is?
Old 07-13-2006, 09:04 AM
The white wire (#21 in the harness) is already fused. You might have to add a ground wire to the socket, although there should be an extra available ground wire in the harness also. All dash grounds are black.
Old 07-13-2006, 09:33 AM
DrC DrC is offline
So I can pick up any old lighter socket or should I go with the ssr suggestion?
Old 07-13-2006, 09:41 AM
cobra's Avatar
Cobra Make, Engine: ERA 427 SC # 571, 472 Shelby aluminum "stroker " CSX # 299 from Gessford, 48 IDA Weber carburetors from Jim Inglese
DrC
Any pictures from your ERA # 711 ?
Greetings from Switzerland
Walter
Walter
http://www.kreuchi-auto.ch
Old 07-13-2006, 09:50 AM
HSSS427's Avatar
I added one to #414 just using the standard wire harness connections that are provided for a lighter. I mounted it under the dash in a vertical position - the opening pointing down to the floor and attached it to the back of the bottom lip of the dash. It's centered between the 2 dash support posts that run up from the tranny tunnel. That way it's not visible, but you can reach under the dash and plug power in.
I run a radar detector and G-Tech off it with a splitter and all seems to work fine. Just have to remember that it's not a switched connection so you have to turn everything off or it will drain the battery.
Old 07-13-2006, 10:17 AM
trularin's Avatar
Member of the north
Depends on what you are doing.
I used the SSR, because I was the validation engineer for the truck and had a few. However, it is rated at 20 to 30 Amps and will handle a 12V mini compressor, not to mention a 12V coffee pot without melting, smoking or starting on fire.
It also has a weather flat that is spring loaded to keep everything else out of the socket. If it rains, the socket stays dry. Third, one thing I really liked, it is held in place by a large hand tighten nut at the back that has a unidirectional cam so it does not come loose.
It is all up to you. Heck, If I knew I had any left, I would send you one.
An inline fuse is a small fuse holder with wires on both sides that can be placed in the 12V delivery line to any device you wish to protect.
Old 07-13-2006, 11:37 AM
DrC DrC is offline
Thanks Truarin for the offer and the exlanation. I like your idea and reasoning. I think I'm going with that. However with that said HSSS427 if I need to go with the "invisable look" your points are VERY valuable.
Rich
Old 07-13-2006, 11:43 AM
DrC DrC is offline
To respond to your question Cobra I not very good at the computer downloading picture thing. Infact not into pictures much at all. If you want to get specific all I really want to do is drive the tires off of cars, in my spare time of course.
Rich
Old 07-13-2006, 11:50 AM
trularin's Avatar
Member of the north
Got to like this guy already.
Old 07-13-2006, 01:49 PM
If you want power that's switched off with the key position, use #20 (green) intended for the heater. It's also fused.
