Old 08-31-2006, 03:50 AM
DrC DrC is offline
Cobra Make, Engine: ERA 711 390 FE w/ TKO 600
Default Straight vs bend shifter
Why does ERA use a bend shifter instead of a straight shifter. Can a straight shifter be used in ERAs?
Old 08-31-2006, 04:18 AM
REDSC400's Avatar
Send a message via AIM to REDSC400
Most all of the original 427 Cobras were equipped with the Ford Toploader transmission. The toploader came with the bent shifter and T bar (lockout from reverse). On the original Ford cars the bent shifter was placed in the car with the bend to the rear of the car. In the Cobra the shifter was flipped 180 degrees and allowed for easier "at hand" shifting.
If you used a straight shifter with a toploader, the shifter would be situated more rearword and you would be shifting with your right arm positioned far back and down... not a comfortable position IMHO.
Additionally, the bent shifter on 427 Cobras reproduces the classic look. If you changed to a straight shifer, many knowledgable folks would query you as to why you would do that.
The straight shifter is used in the 289 Cobra that ERA makes.
Art in CT
Old 08-31-2006, 05:47 AM
DrC DrC is offline
Great info. Thanks
Old 08-31-2006, 06:07 AM
Cobra Make, Engine: ERA #678 427SO/468 Cu in.
Default Question on shifter
Always wondered why the Reverse lockout is never used. Seems like it could be useful?
Old 08-31-2006, 08:29 AM
Unfortunately neither the Hurst nor Long shifter has provisions to use the lockout on the lever. We just keep it for the proper look.
Old 03-05-2007, 01:44 PM
Ant Ant is offline
Default Shifter
strictlypersonal,
Do you know which shifter eg T5 or FFR reproduction 427 style shifter fits the long style shifter 2 bolt upright pattern?
A J. Newton
The 1960's rocked!
Old 03-05-2007, 02:05 PM
d_ford's Avatar
Cobra Make, Engine: CSX4000, Shelby aluminum 496 ci FE
My ERA uses the original ford shifter turned backward that has not been cut down so the lockout still works. It looks tall but actually fits and shifts very nicely. I thought about cutting it down per the manual but it works too well as-is.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
Old 03-05-2007, 02:47 PM
Jim Holden's Avatar
Cobra Make, Engine: ERA140, ERA 267, ERA GT2038, ERA FIA 2045, ERAGT2077 ERA2893000EXP
While the "backward" shifter may look awkward to the uninitiated, it actually makes shifting much easier than it would otherwise be if it were installed "normally" or with a straight up and down lever. With the reversed shift lever, the shift ball is located where your hand naturally drops when you remove it from the steering wheel and the shifter motion is quite natural. It made sense 40 years ago and it still does.
Old 03-05-2007, 03:23 PM
FUNFER2's Avatar
I believe the shifter handle was borrowed from the Mustang and turned backward.
Kevin
Old 03-05-2007, 05:38 PM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default My memory is not what it used to be
I swear the original style shifter is the same as the one in my 1969 Mustang fastback with the console.
Old 03-06-2007, 08:36 AM
Cobra Make, Engine: None yet
Default Straight vs. Bend Shifter
I don't think the shifter was borrowed from a Mustang. If memory serves me right, the shifter and tranny was from 1964 Ford Galaxy and turned backwards. It was the only way Shelby could make the shifter work with the toploader transmission. Mustang didn't come along until April of '64. And it was formed off the old Falcon platform so parts for it were lighter than the old Galaxy.
Old 03-06-2007, 09:34 AM
Shelby had access to parts and supplies not yet available to the general public and often parts never released to the public.
But it is an interesting question: Galaxie or Mustang?
Old 03-06-2007, 10:00 AM
Excaliber what you say about Shelby is very true. I'm trying to remember what year the 427 Cobra came out was it '64 or '65? Anyway my point is this. He used the power train that had come out on the '64 Galaxy. Under the right conditions you could special order a 427 SO with 4 speed. I know because I knew a guy back home that had one. It was black with the aluminum bumpers and it looked mean just sitting still. So for the sake of economics it's easier to use what Ford already had sitting on the shelf. That's why later on he used the 428 engine because they were so much cheaper.
Old 03-06-2007, 01:58 PM
Tony Radford's Avatar
I must confess my deviation from accuracy. I was a bit particular about my shifter location. I searched far and wide to get the configuration I needed for a comfortable feel.
Old 03-06-2007, 02:03 PM
Cool
Hey whatever works. I don't think ole Carrol would mind. Myself I prefer the original look
Old 03-06-2007, 04:06 PM
Deviation from accuracy will not be tolerated!!
OK, except for maybe Tony in this one case.
Old 03-06-2007, 04:13 PM
d_ford's Avatar
Wouldn't the galaxy toploader tail shaft be too long and put the shifter location too far rearward? I always heard that it was borrowed from the mustang but I guess I really don't know.
Doug
CSX4761
ERA #115 - sold
ERA #002 - sold
07 GT500
66 GT350 tribute
70 Mach 1
65 Comet gasser
Old 03-06-2007, 05:30 PM
Chaplin's Avatar
Surprisingly good answer from someone with less than 10 miles on their car
Replica is not a dirty word.
Old 03-06-2007, 07:52 PM
Send a message via MSN to spl310
The 289 cars used the galaxie transmission as the shifter is mounted well forward. It came out in a perfect location, but they had to make the stubby straight shifter for it as the others were too long. When Shelby started stuffing in the 427, they needed a shorter transmission, so they went with the Mustang unit. The problem is that the Mustang unit puts the shifter at the end of the tailshaft. Flipping the Mustang lever solved the problem.
Old 03-07-2007, 10:03 AM
I stand corrected. I honestly didn't think they used parts from the Mustang. But then again my memory ain't what it used to be. Thanks for correcting me. Goes to show we are never too old to learn something new.
