Old 03-11-2007, 10:28 AM
birddog's Avatar
Cobra Make, Engine: ERA 289 FIA #2009, Boss 302
Default Starting Question - electric choke
I need a little help. I have had fuel injected cars for so long I don't know how to start a carb engine. My ERA has a '69 BOSS 302 with a Holley 650 CFM, vacuum secondary and electric choke. What is the best method of starting? The engine turns easly and does fire on the first or 2nd try but doesn't start easily. There must be a trick that I haven't figured out. When RCT delivered the car, Rich started it easily and that was 20 deg. weather. I will have to see if he remembers but I assume I am making a basic mistake. The engine does idle pretty rough upon startup but once warm,runs wicked.
Old 03-11-2007, 11:05 AM
Cobra Make, Engine: SPF 2473, Roush 427R
Treat your electric choke like a manual choke. Push gas all the way to floor and release. Engine should start right up. Don't pump it.
Old 03-11-2007, 11:36 AM
When it's really cold, it might prefer a couple of pumps before cranking, but Goopie has it right. It's not necessary to go all the way to the floor. Anything past 1/8 throttle should set the choke plate into its cold-start position.
If the engine idles roughly after it fires up, you might have to adjust the idle cam and/or the choke position to tweak it to the ideal mixture.
If it's warm out, you might want to crack the throttle open a bit while you crank to avoid flooding the engine.
Old 03-11-2007, 12:08 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Try the 'step once on the gas and then turn it over method'.
By stepping on the gas, you set the choke and allow the engine to draft more gas than air while it is cold.
Old 03-11-2007, 06:53 PM
birddog's Avatar
Thank you for the quick replies! I will test a few nights this week and see how things go. I think I was a little heavy with the throttle.
Old 03-12-2007, 04:47 AM
Cobra Make, Engine: LA Exotic
My 351w with 600 holly was hard to start in cold weather...Check the clearance on the air cleaner...mine was holding the choke in the open position..would not let it close after depressing the accelertor pedal as described in the pump once and start method...installed a 1/2 spacer on the carb...also gained 17hp at the rear wheels...better air flow.
Old 03-12-2007, 05:42 AM
wtm442's Avatar
Beam Me Up Scottie
Turn the key to ON position
Floor the gas pedal and release
Start the car
Warren
Old 03-27-2007, 05:12 PM
birddog's Avatar
Thanks for the help. The recommendations did the trick. Car starts on the first try. Jeff
